Spraying epoxy
Miken
PostPosted: Thu Jan 16, 2014 10:40 pm    Post subject: Spraying epoxy Reply with quote
Ive sprayed a fair amount of cellulose over the years.
I would like to have a go at spraying 2 part epoxy primer.
Do I need a special or different type of spray gun ? What size nozzle?
An expensive gun would probably be wasted on me so what is a reasonable gun to practice with?
Thanks
Mike
petermeachem
PostPosted: Thu Jan 16, 2014 11:17 pm    Post subject: Reply with quote
You mean like the rustbuster stuff? Considering it was my first go at spraying I was very pleased with the results. I just used a standard lvlp gun with a 1.4 nozzle, there are no special requirements. One of these http://www.ebay.co.uk/itm/BERGEN-Professional-LVLP-Gravity-Fed-Spray-Gun-500ml-Capacity-1-4mm-Nozl-79-99-/390747179593
I could have cleaned the gun out better, there was a wee bit left which dribbled out from somewhere. I scraped it out carefully, the gun is fine. I'm told that cellulose thinner is fine for washing it if you give it a good sloshing around. Rustbuster do recommend their own thinner for cleaning. You have plenty of time, the pot life once mixed is 8 hours
Miken
PostPosted: Fri Jan 17, 2014 12:38 pm    Post subject: Reply with quote
Thanks for the reply,
I will try a gun like that.
This is the stuff I have bought:
http://www.ebay.co.uk/itm/METAL-PAINT-2-PACK-EPOXY-/131082031685?pt=UK_DIY_Material_Paint_Varnish_MJ&var=&hash=item1e85191245#ht_869wt_1161
MN
