natboy
Posted: Sat Mar 15, 2014 8:10 pm Post subject: Floor Painting |
Hi Folks,
I want to paint the floor pans and tunnel on the inside of my mk 2 cortina i was wordering should i strip it back to bare metal and one coat of epoxy primer followed by 3 coats of celly primer and then a top coat. What do you think? any ideas? thanks. |
Posted: Sat Mar 15, 2014 11:31 pm Post subject: |
Never tried epoxy yet (too expensive) but most comes unstuck in regular use after 2 years but anything is better than nothing and cheap stuff is easy to renew _________________ Rover P2
ka
Posted: Sun Mar 16, 2014 7:41 am Post subject: |
Depends on the finish required. If you are after concours, then your suggestion reads well, but if you intend to replace the carpets, seems a lot of trouble. If you have access to an air gun (or if not available in aerosol form), you can buy a ruberised covering, that will give far greater abrasion resistance against the carpet, then paint. _________________ KA
Better three than four. |
natboy
Posted: Fri Mar 21, 2014 9:12 pm Post subject: |
| Thanks for the advise folks |
stevel98
Posted: Wed Apr 16, 2014 12:58 pm Post subject: |
I just use Hammerite.. Easy to touch up and no hassle should I need a bit of welding done later.. Leave the sound insulation to the proper stuff.
Cheers, |
