stag geek mk.1
Posted: Thu May 08, 2014 9:58 pm Post subject: HERITAGE CERTIFICATE |
Hi can anyone tell me how i go about getting a heritage certifate for my 1972 Triumph Stag thank you Martin  |
Norfolkjohn
Joined: 07 Mar 2011 Posts: 88 Location: North Norfolk
Posted: Thu May 08, 2014 11:39 pm Post subject: |
You should have no problem at all in getting a Heritage Certificate from BMIHT. They have full records for all post war Triumphs up to 1984. You can apply for a Certificate on line via the following link (just select the specific type of Certificate you want and fill in the required details):
http://www.heritage-motor-centre.co.uk/store/heritage-certificates-and-archive-services.html
The only significant detail you need is the chassis / commission number. This will be on the V5 and should also be on a data plate which I expect is in the engine bay (if it is like a on TR).
Cheers, J _________________ One thorn of experience is worth a whole wilderness of warning |
