Classic Quotes from your Classic or Vintage Owners Manual?
PostPosted: Tue Jun 24, 2014 8:16 am    Post subject: Classic Quotes from your Classic or Vintage Owners Manual? Reply with quote
Following on from Tony's quote from his Fiat 500 bible:
"Air conditioning in the car interior is obtained by suitably adjusting swivel ventilator panels on doors. Moreover, when door drop glasses are cranked part way or all the way down, admission of outside air is increased to a remarkable extent, affording better ventilation in the car interior".
Any others out there I wonder?
PostPosted: Tue Jun 24, 2014 8:21 am    Post subject: Reply with quote
One from the MG SA repair manual..
"Owing to the fact that the total number of links in the timing chain is a prime number, the engine must be turned fifty-eight times before the links and marked teeth come back to this position again."
Ashley
PostPosted: Tue Jun 24, 2014 11:59 am    Post subject: Reply with quote
I had a Ducati 750GT many years ago and I still remember the Brake light switch: "it is a new type of switch with unfailing operation. It is worked by the rear brake and sheath wire inserting it intermittently".
baconsdozen
PostPosted: Tue Jun 24, 2014 12:51 pm    Post subject: Reply with quote
From my old handbook for the CB72 motorcycle. "Riding with the choke out will cause staining of the sky".
PostPosted: Tue Jun 24, 2014 2:18 pm    Post subject: Reply with quote
Not from a classic car manual, but a classic piece of Japanese/English from a manual handed to me by a student with an ignition fault on his motorbike. The section started thus................
"If indeed the engine is missing the fire...................." Shocked
Jim.
By the way, I love yours BaconsDozen!
swampy
PostPosted: Tue Jun 24, 2014 8:33 pm    Post subject: Reply with quote
Well here is my contribution (brings a smile to my face anyway)
From the "Handbook of Instructions for the Jensen Interceptor"
"The driver who wishes occasionally to indulge in a very fast get-away will obtain the maximum acceleration by allowing the automatic gearbox to make full throttle changes throughout the speed range"
This little bit of gentlemanly understatement is followed by the section on kick-down:
"In an emergency or when a sudden surge forward is desired, the kick-down feature allows the driver to change down while obtaining maximum engine speed, and without removing his hands from the wheel, by depressing the accelerator pedal to the floor."
This is all good advice and great fun - especially holding the steering wheel with both hands whilst flooring it Twisted Evil
Hope it makes someone else smile.
Rosco663
PostPosted: Wed Jun 25, 2014 5:15 am    Post subject: Reply with quote
Excerpt from Series II Morris 8 manual.
"General Hints on Driving
Filling up
(I) Petrol
Before starting out for a run always make a point of seeing that the tank contains sufficient petrol............"
I tried, a couple of times, to impress this on my son in his novice driving years. After the inevitable 'rescue missions' Cool
Rosco
PostPosted: Wed Jun 25, 2014 6:29 pm    Post subject: Reply with quote
From the Austin 7 box saloon handbook:
"The Austin Seven is particularly suitable for the woman driver. It requires little physical effort to drive and control, and for that reason its use enables her to do shopping calls without fatigue, visit her friends, attend social and other functions, or make excursions or trips in any direction in any weather."
baconsdozen
PostPosted: Wed Jun 25, 2014 9:41 pm    Post subject: Reply with quote
I can't remember which car it was but one model used to have "Press firmly" on the starter button as (so it was said) drivers were a bit wary of the new fangled electric starters.
Rosco663
PostPosted: Thu Jun 26, 2014 4:51 am    Post subject: Reply with quote
Nice one Rick Cool
Best I get the Missus an Austin Seven. This way I should be able to have her out and about which will give me more time to finish my other projects Very Happy
Rosco
Ashley
PostPosted: Thu Jun 26, 2014 9:12 am    Post subject: Reply with quote
It was absolutely right except seventy years on they do the same in monster 4 x 4s round here. And come the school run it's like dodging the German fleet in Scapa Flow! Sad
PostPosted: Thu Jun 26, 2014 9:29 am    Post subject: Reply with quote
Good one Ashley!
Over here it's the Japanese as well as the Germans 4 x 4's on the school run! You gotta wonder who won the dammed war!
Keith
