Screwing door card to door - need some type of insert
rcx822
PostPosted: Wed Aug 06, 2014 6:24 pm    Post subject: Screwing door card to door - need some type of insert Reply with quote
I'm trying to replace the rotted door cards with some simply plywood cards. The original doorcard used plastic clips which won't really work. Ideally I would simply screw through the plywood and into the metal behind. As it's a 4x4, the simple plywood with pan headed screws would add to the jeep look.
Original clips were like these:
I could use something like these, but they won't be as secure as pan head screws:
Here's the door:
Some of the holes are square, and have one of these plastic inserts. Almost perfect! But I need inserts which would go into a round hole.
Any other ideas? Or where to buy such inserts that would go into round holes?
PostPosted: Wed Aug 06, 2014 6:47 pm    Post subject: Reply with quote
Here?
http://www.bresco.com/acatalog/Best_Sellers.html
PostPosted: Wed Aug 06, 2014 7:17 pm    Post subject: Reply with quote
What about using a rivnut?
http://www.bollhoff.co.uk/en/uk/fasteners/special_fasteners/riveting_technology/rivnut.php
Kev
PostPosted: Wed Aug 06, 2014 7:39 pm    Post subject: Reply with quote
Just thinking sideways a bit, maybe something like these http://www.screwfix.com/p/rawlplug-self-drill-plasterboard-fixings-nylon-32mm-pack-of-100/97406
or these http://www.screwfix.com/p/hollow-wall-anchors-8-16mm-x-52mm-pack-of-10/12229
Usual caveat with Screwfix, don't assume they're the cheapest!
rcx822
PostPosted: Wed Aug 06, 2014 8:03 pm    Post subject: Reply with quote
Well Bresco sell it all! What a find! I always dreaded that I won't find all those funky type of fasteners that my car needs!
I like the Screwfix solution as well.
Thanks all!!
