JohnDale
Posted: Sun Oct 05, 2014 4:42 pm Post subject: Weren't we clever when we were young? |
Looking at Peter's pic of the 4/50(in Richards Doctor Who post) & seeing the heater control under the dash brought back a memory of long ago. When I was an apprentice (2nd year)my father had a Morris 10M which had no heater so he decided to purchase one(by mail order even then) When it arrived the aluminium bracket(which has the control levers in it) was broken. He wanted to send it back but, of course, with all the experience of youth, & having been taught to weld, I persuaded him I could repair it. When he was presented with a ball of melted aluminium he was not well pleased - no one had told me(my excuse) that ally didn't weld like mild steel. Ah well,lesson learned,cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
Dobbin
Joined: 15 May 2013 Posts: 67 Location: Central Scotland
Posted: Sun Oct 05, 2014 5:29 pm Post subject: |
| JD, I can relate to that. When I was also a 2nd year apprentice I was being shown how to weld aluminium with a gas torch. I gathered together some off cuts of aluminium from the back of the guillotine and with the eagerness of youth set to it. Unfortunately as Mickey mouse found out in the sorcerers apprentice it can go pear shaped very quickly. I ended up with some very rough holes and silver boots........... |
lowdrag
Posted: Mon Oct 06, 2014 9:14 am Post subject: |
While converting my D-type to an XKSS a couple of years back one clever fellow asked about how I was getting on fabricating the GRP panels, plus a few other rather sarcastic quotes. I replied that since the invention of the new GRP welding process things were very much easier. You know, he sent me a pm asking for a link to the welding technique!
So don't despair, the process is ongoing still! |
JohnDale
Posted: Mon Oct 06, 2014 9:52 am Post subject: |
| Dobbin wrote: | | JD, I can relate to that. When I was also a 2nd year apprentice I was being shown how to weld aluminium with a gas torch. I gathered together some off cuts of aluminium from the back of the guillotine and with the eagerness of youth set to it. Unfortunately as Mickey mouse found out in the sorcerers apprentice it can go pear shaped very quickly. I ended up with some very rough holes and silver boots........... |
Hi Stuart, maybe that was something they did to second year apprentices to bring them down to earth & show they didn't know everything. Must have worked 'cos fifty odd years later I'm still learning,cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
Dobbin
Posted: Mon Oct 06, 2014 1:04 pm Post subject: |
JD I agree, whoever came up with the saying 'everyday's a school day' wasn't wrong. I have left that school and enrolled at the university of hard knocks...........However I don't think at this rate I'm ever going to graduate......hehehe  |
alanb
Posted: Mon Oct 06, 2014 1:23 pm Post subject: |
The problem these days is trying to remember what I did learn! _________________ old tourer
Morris 8 two seater |
Old Wrench
Posted: Mon Oct 06, 2014 3:29 pm Post subject: |
Gas welding ally sheet is not actually hard: it is as normal, simply a matter of following procedure and practice.
The old boys gas welding Aston e.g. bodies, made from aluminium alloy, used to wipe soft green household soap along the line to be joined and watch the colour change as they progressed.
Always a much smaller tip and much lower gas pressures than normal.
Always use a slightly carburizing flame: i.e. less Oxygen. This reduces the effective tip heat.
Same for ally castings: the trick here is to bring the part up to as high a temperature as possible before welding: and cover in old sacks, sand etc afterwards to allow the casting to cool slowly and not induce strain stresses and subsequent cracks.
Learn to carefully watch the "puddle" develop as the material approaches smelt point.
For filler rods when welding sheet, simply cut off thin strips as wide as the material is thick. For casting use a standard pure ally filler rod.
First quality ally flux is also essential: not "Soldering Flux" by welding flux.
I found melting ally is very similar to melting lead: too much heat and it's on your boots! |
Old Wrench
Posted: Mon Oct 06, 2014 6:08 pm Post subject: |
I have heard of this new approach, Peter: first saw it on a US welding site some years back.
Looks like an excellent result!
Today, of course, TIG and Inverter Welding have taken over where MIG left off.
Some few years ago, I had a cum of mine rebuild around a valve seat using TIG on an ally BMW six cylinder head and he pressed in a new valve seat. (Dropped a valve).
Astounding result. |
Riley Blue
Posted: Mon Oct 06, 2014 8:05 pm Post subject: |
| alanb wrote: | | The problem these days is trying to remember what I did learn! |
It's easy to remember what I learnt - nothing of any use whatsoever.... ! _________________ David
1963 Riley 1.5
1965 Riley 1.5 |
JohnDale
Posted: Tue Oct 07, 2014 12:53 pm Post subject: |
There is one thing which we appear to have learned very quickly but which stays with us right through life - when to stay quiet & let someone else put their foot in it!! Works with wives too(if you have one) Cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
