David Kipling
Posted: Tue Dec 09, 2014 7:55 am Post subject: Mystery late 50s or early 60s rear-engined model- |
I'm trying to identify the original make and model that was cannibalized for the body of a 1960s English stock-car.
It was assembled in the mid 60s from a scrapped vehicle that would have been late 50s or very early 60s.
The body has a louvred rear engine lid, with distinctive hinges, and at first I thought Fiat 600, but Fiat 500s and 600s always had a generous space between the "runs" of louvres, for a licence plate. And 500s did not have those hinges.
It is no Renault I ever saw.
Most of the cabin and rear were from the same original car. If someone could have a guess, I would be very grateful.
It has to be from a rear-engine car. Here is na link to the only photo I have.
http://www.oldstox.com/images/ellard%20query.jpg
I still think "Fiat", but it's not.
Posted: Tue Dec 09, 2014 10:19 am Post subject: |
I think those are VW wheels so maybe a beetle power unit?
David Kipling
Posted: Tue Dec 09, 2014 4:28 pm Post subject: |
| peter scott wrote: | I think those are VW wheels so maybe a beetle power unit?
Peter |
Thanks to both of you. Renault 4CV is close but not quite. The louvred "engine cover" is very flat, even flatter than a Fiat, unless there's an early Fiat I'm not aware of.
The chap who built the stock-car builder insists the donor car was a 1950's. |
Posted: Tue Dec 09, 2014 4:37 pm Post subject: |
Fiat 600 Multipla?
David Kipling
Posted: Tue Dec 09, 2014 5:40 pm Post subject: |
[quote="D4B"]Fiat 600 Multipla?
That is CLOSE, except for the darn licence-plate gap that doesn't seem to be there on the stock car.
The Multipla has 14 louvres, but there are only 8 p the stock car.
Posted: Tue Dec 09, 2014 5:48 pm Post subject: |
I guess the on the stock car the wheels are fitted wrong way around to give a wider track.
vitesse
Posted: Tue Dec 09, 2014 7:04 pm Post subject: |
I think it is definitely a 600 saloon rather than a multipla. The Mulitpla's back rear window comes down and meets at a point. On a 600 saloon it doesn't it sort of flattens off as it does on the stock car.
As for the vents, I think the original picture foreshortens the impression, so as to make the vents appear nearer together. If you look at the hinges on two pictures Steve posted you will see what I mean. Hopefully. As for the number of them, it could have been modded to reduce the number of them for some reason or it could be a derivative? The 600's were built by a number of different companies in Europe like SEAT.
Tony |
Posted: Tue Dec 09, 2014 7:25 pm Post subject: |
I agree about the Fiat rear door but the the Multipla wheels and rear drums are totally different to those in the photo.
vitesse
Posted: Tue Dec 09, 2014 8:13 pm Post subject: |
| peter scott wrote: | I agree about the Fiat rear door but the the Multipla wheels and rear drums are totally different to those in the photo.
As you pointed out before Peter they are fitted the wrong way round on the stock car, also they are much larger than the original wheels, hence the wheel arch being chopped off. Could be traction again or simply gearing to give it a more oomph!!!!
Tony |
David Kipling
Posted: Wed Dec 10, 2014 2:34 am Post subject: |
Tony[/quote]
Again I wish to thank the prompt and POLITE respondents to my query (not all car forums are so hospitable to oddball enquiries). Yes, most drivers reversed their rims to slightly widen the effective track.
Yes, I understand that "foreshortening" in the photo may well disguise a licence plate gap, and it may also tend to show the cover as being flatter thanit was in three dimensions
If Fiats were built by a variety of contractors, yes, the louvre count may have varied.
The distinctive shape of the rearmost part of the side window is definitely Fiat 600 design. I will try to contact the original builder again. I have since found that 600s were built and sold as early as 1955 --- I'd not known that --- and so a well-worn 600 may well have been scrapped by around 1960-61.
Thank you all againb, I am most grateful and appreciative.
I will keep my eyes on the thread, in case |
Posted: Wed Dec 10, 2014 9:11 am Post subject: |
Hi David,
I fully accept the use of Fiat body panels but I would suggest that the builder of this car will not have mated a Fiat engine to the rather obvious VW Beetle 5 stud brake drums and hubs. If you are using VW hubs and drums then you are most likely using a VW transaxle and engine.
p.s. The Beetle wheel that I pictured above is mounted on a front brake drum. The rears were as in your photo and not knobbly. _________________ https://www.nostalgiatech.co.uk
Posted: Wed Dec 10, 2014 9:29 am Post subject: |
Peter, is it not possible that the wheels on the stock car could have been Renault 4CV? Here's a Renault 4CV wheel:
