rcx822
Posted: Fri Dec 12, 2014 10:03 am Post subject: Advise on replacing fuel pipes |
I have a 1980's Suzuki Vitara, it's just had a full overhaul, just some loose ends to tie up and then painting.
The steel fuel pipes are rusting, not enough to fail an MOT, but enough for a sensible person to be concerned. There's three fuel pipes running along the chassis, one is for the common rail, one I understand is the return, and one breather which goes to a charcoal can.
Different people have advised different things, so I wanted to get some advice here:
A couple of people mentioned nylon hose. I'm told modern cars use it. I'm not that keen on it because it cannot be shaped like copper or alloy, and unlike rubber hose, it tries hard to return to its original straight shape. Also, the car gets used off road and I'm worried it could puncture.
Copper has been suggested. I can shape it by hand. I've heard it needs to be automotive copper.
A specialist shop has suggested using alloy tube. Can be shaped by hand. Maybe safer than copper? Certainly cheaper!
The same specialist shop, plus a competition supplier, also said that flexible hose is often used. The competition shop advised against cheap hose saying it won't last. The expensive stuff is £30/m and I have three runs to do!
I also need to bear in mind that I have two 4 guage winch cables, and soon also a pneumatic nylon hose for the rear diff lock, so "cable" management is an issue. I may be looking at custom mounts to organise all that. |
Old Wrench
Posted: Fri Dec 12, 2014 11:00 am Post subject: |
Alloy tube corrodes very quickly, particularly if exposed under the vehicle.
Same comment with steel bundy tubing.
I would go with copper: every time. _________________ Well, apart from that, did you enjoy the play, Mrs Lincoln? |
Posted: Fri Dec 12, 2014 12:50 pm Post subject: |
I would go with Copper Nickel, it is stronger than just copper. Used it on my Peugeot D4B for fuel line front to rear.
rcx822
Posted: Fri Dec 12, 2014 1:00 pm Post subject: |
| Yes I keep reading that pure copper hardens and shouldn't be used. Yet even Halfords sell pure copper brake pipe. |
Posted: Fri Dec 12, 2014 1:02 pm Post subject: |
I would agree with BD4 and add that you need to change the rubber flexi side of things for some high quality rubber pipe with proper fuel line fittings (as opposed to jubilee type) and rubber lined chassis fixings. worth doing right and doing once.
Bought my last lot of pipe and fittings from Demon Tweeks, great service and excellent quality.
Kev |
Old Wrench
Posted: Fri Dec 12, 2014 3:30 pm Post subject: |
| rcx822 wrote: | | Yes I keep reading that pure copper hardens and shouldn't be used. Yet even Halfords sell pure copper brake pipe. |
All malleable metals harden over time!
Indeed, for example, French copper plumbing pipe (much thicker wall than UK, BTW)is sold as ready-annealed, or hard.
To bend the hard stuff, you must firstly, anneal it.
What is critical is surely the reaction of the copper pipe to the fuel?
If properly clenched, regularly, then the pipe is not going to vibrate and work harden and thus fracture.
However, all synthetic "rubber" tube degrades over time. Plus the action of even modest amounts of Ethanol in petrol, degrades the molecules, as most synthetic flexible tubing is made from Long Chain Molecules. _________________ Well, apart from that, did you enjoy the play, Mrs Lincoln? |
Joined: 23 Nov 2007 Posts: 4267 Location: South Cheshire
Posted: Fri Dec 12, 2014 6:10 pm Post subject: |
Copper pipe can be annealed quite easily and it's worth doing after its bent to shape ( which tends to harden it) and before its fitted; simply heat to cherry red with a blow lamp and then quench the pipe in a bucket of cold water.
Pre war Morris vehicles fitted with hydraulic brakes originaly had copper brake pipes, and some of those original pipes are still in use today. I have heard of owner's removing them as part of a rebuild and annealing the pipes, so they should be good for another 80 years!
rcx822
Posted: Fri Dec 12, 2014 6:18 pm Post subject: |
Which way round is it, annealing is where you soften or harden it? I thought that annealing is where a work hardened material is heated and allowed to cool naturally so that the molecules can fall back into a relaxed position, but looks like I have it wrong?
Regarding the reaction of copper pipe to fuel, I've read that automotive copper is safe while plumbing copper has been known to causing gumming (whatever that is?). Again I don't really know hence my questions! |
Posted: Fri Dec 12, 2014 6:48 pm Post subject: |
| rcx822 wrote: | Which way round is it, annealing is where you soften or harden it? I thought that annealing is where a work hardened material is heated and allowed to cool naturally so that the molecules can fall back into a relaxed position, but looks like I have it wrong?
Regarding the reaction of copper pipe to fuel, I've read that automotive copper is safe while plumbing copper has been known to causing gumming (whatever that is?). Again I don't really know hence my questions! | Hi
Annealing a metal will "soften" it. Different metals require different processes to anneal or harden, if you use the process I described for anealing copper on steel it would harden it.
I have never heard the terms automotive copper or plumbing copper, there are loads of different copper alloys , in my electrical engineering days we used to specify oxygen free copper cable (virtually pure copper) for certain applications, I'd imagine this copper would also have a better resistance to corrosion?
Just had another thought, we are on oil heating, the pipe from the tank to the boiler was supplied by plumb centre.......but it contains fuel ...it all works !,
rcx822
Posted: Fri Dec 12, 2014 7:31 pm Post subject: |
| All good. So copper it is! I will go for the copper nickel stuff. Flare the ends and use proper fittings as it currently is set up. The flexible rubber on each end is in very good condition so it will remain. |
Old Wrench
Posted: Fri Dec 12, 2014 8:40 pm Post subject: |
| ukdave2002 wrote: |
I have never heard the terms automotive copper or plumbing copper, there are loads of different copper alloys , in my electrical engineering days we used to specify oxygen free copper cable (virtually pure copper) for certain applications, I'd imagine this copper would also have a better resistance to corrosion? |
Neither have I, Dave.
| Quote: | Just had another thought, we are on oil heating, the pipe from the tank to the boiler was supplied by plumb centre.......but it contains fuel ...it all works !,
In France, oil heating is pretty much ubiquitous: and the oil is fed through copper tubing, 8, 10,or 12 MM Dia.
One buys it in coils : same in fact as plumbing pipe 14, 16, 18, MM dia.
The coils need annealing before trying to bend: the straight tubing does not need annealing.
I did once try to bend some 16 MM without annealing: and broke the former on the bender! _________________ Well, apart from that, did you enjoy the play, Mrs Lincoln? |
rcx822
Posted: Tue Dec 16, 2014 4:22 pm Post subject: |
What sort of fittings are normally used with copper fuel pipe? Compression? Solder on?
I think I will need to make an adaptor or fitting as I need to ultimately get to a 14mm x 1.0 pitch female (non tapered) which will receive an equivalent male with a a "conical" shape at the end to create the seal. |
Old Wrench
Miken
Posted: Sat Jan 03, 2015 12:04 pm Post subject: |
My 81 year old Morris Minor has what i strongly suspect is the original 1/4" dia copper fuel pipe. So I feel confident in stating that it should be fine for this application.
It has 60 degree brass union fittings at either end. I have just had to replace one of the unions because it was slightly damaged. These are simply soft soldered to the copper tube.
Mike |
Posted: Sat Jan 03, 2015 12:48 pm Post subject: |
I have never understood why, but in the UK OFTEC state that soft soldered joints should not be used on domestic heating fuel supply pipes?
