Body off restoration. Positives and negatives.your views
Minxy
PostPosted: Sun Feb 01, 2015 10:57 am    Post subject: Body off restoration. Positives and negatives.your views Reply with quote
Hello all.
So I have never done it on an old car that had a separate chassis and tub. I used to build rally cars as a job and I have done several re-shells on modern cars some years ago.
So knowledge isn't an obstacle and I have a 7metre square garage with upstairs storage space so can anyone advise the pitfalls I could expect beyond those of space and skill set.
Thanks in advance
PostPosted: Sun Feb 01, 2015 11:06 am    Post subject: Reply with quote
I think it's better if you can avoid it but if serious corrosion needs attention then it makes life very much simpler.
Clearly you need to tie the body together so that it doesn't collapse when it's lifted off and you also need to ensure that you have good strong lifting points.
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=7917
PostPosted: Sun Feb 01, 2015 11:08 am    Post subject: Reply with quote
7m square garage! That's about the size of 4 phone box's Wink ...I know what you mean Smile
I did my MGA as a body off restoration. Disadvantage is time space, and the possibility of the body flexing or distorting, so I replaced the sills when the body was still on the chassis and as it was a roadster made a frame out of angle iron that held the top of the body together, before I lifted the body off.
Advantages are that you can restore to a factory spec, many jobs are easier because of the better access available with the body off. Painting especially as the body in most cases would have been painted separately to the chassis.
I guess the ultamate question for me would be"how much restoration is required" I'm currently working on moy Morris Z van, I could take the body off , but frankly I can get at everything that bed restoring with it on ( I hope I don't regret saying that as the restoration advances!)
What vehicle is it you have?
PostPosted: Tue Feb 24, 2015 4:15 pm    Post subject: Reply with quote
Personally I wouldn't take the body off if I had a choice. I would only do it if I were restoring to concours (which I wouldn't) or if the tube was so shot it required it.
I suppose in essence it is down to what or how much work is needed?
PostPosted: Tue Feb 24, 2015 5:42 pm    Post subject: Reply with quote
If it has a separate chassis and that needs serious welding YES, otherwise NO
Having restored one "body-off" car it occurs to me that the reason I did it was because all the books and magazines implied that you had to for a serious restoration. In fact it was largely pointless and created a few problems for me.
