Ronniej
Joined: 02 Dec 2008 Posts: 239 Location: Blackwood, by Lanark, Scotland
Posted: Fri Feb 13, 2015 12:26 pm Post subject: ADVICE ON PAINTING A GARAGE FLOOR |
Forgive me if I am going just a bit off topic here.
I will shortly be taking over a new garage and the concrete floor is completely unpainted. I want to paint it before I put my slightly incontinent cars into it.
There are plenty brands of floor paint available but I would appreciate advice on what would be best.
Can anyone give advice based on experience?
Ronnie J |
Posted: Fri Feb 13, 2015 7:17 pm Post subject: |
I gave up continually repainting mine - it stuck to the tyres every-time it was wet _________________ Rover P2
Posted: Fri Feb 13, 2015 7:30 pm Post subject: |
Phil - Nottingham wrote: | I gave up continually repainting mine - it stuck to the tyres every-time it was wet |
That shoulnt happen if its epoxy based
Kev |
Joined: 23 Nov 2007 Posts: 4240 Location: South Cheshire
Posted: Fri Feb 13, 2015 8:45 pm Post subject: |
Did you use floor sealer first? Perhaps the paint never properly adhered to a dusty surface? |
Posted: Fri Feb 13, 2015 8:48 pm Post subject: |
It does look good but it would cost a bit now for almost 30 sq mtrs _________________ Rover P2
Ronniej
Posted: Mon Feb 16, 2015 2:40 pm Post subject: ADVICE ON PAINTING A GARAGE FLOOR |
Thanks everyone.
The replies have raised a question I had not thought about.
The floor in question is unpainted concrete but is presently free of any oil spillage.
I had intended just to pressure wash it to clean up before painting it.
Would it be better to apply some sealant first?
Ronnie |
Posted: Mon Feb 16, 2015 4:31 pm Post subject: Re: ADVICE ON PAINTING A GARAGE FLOOR |
Ronniej wrote: | Thanks everyone.
Ronnie |
you would need to speak with the manufacturer of the floor paint system as they all differ.
Kev |
Posted: Mon Feb 16, 2015 6:01 pm Post subject: |
I would say if you notice fresh concrete dust every time you sweep, then it will need sealing first.
Concrete will suck the new floor paint in so I guess if you don't seal it you just end up using extra paint? |
Posted: Mon Feb 16, 2015 7:18 pm Post subject: |
I used a sealer harder specially for dusty concrete floors. The paint stuck to it and came up with sealer. The floor was clean new concrete (6 months old and no oil) _________________ Rover P2
Posted: Mon Feb 16, 2015 11:54 pm Post subject: |
If the floor is dusty (which it probably will be as it's new) then it's best to hir a floor grinder and remove the soft top layer before sealing the hard concrete underneath
This is the aggregate showing through after grinding
I've done all I'm going to do as far as grinding the floor is concerned. Edges and corners tidied up and the floor hosed down to remove the dust. Now I need to wait on it drying out and also for some slightly warmer weather before applying the sealant
 _________________ ROVER
One of Britain's Fine Cars |
Posted: Mon Feb 16, 2015 11:57 pm Post subject: |
I've just been out to the garage this morning and the floor is drying out nicely. I really do fancy the clear coat finish if anyone can recommend the 'right' product
The next day the floor was drying out
The floor is now sealed and I don't have any more dust problems
Posted: Tue Feb 17, 2015 12:25 am Post subject: |
I wish I had done mine like that before I filled it. It would be big messy job to even paint it now
ka
Posted: Tue Feb 17, 2015 7:53 am Post subject: |
When we designed the house and then had it built, I designed in a garage of 70sq m, with two electric/remote controlled up and over doors, and also a normal door leading to the garden through a toilet that is always handy to wash hands etc when either spannering or gardening.
I also chose to paint the floor with purpose made floor paint on top of the new concrete. Mammoth job, ended up poring it on to the floor, and using a sacrificial soft hair sweeping brush.
But back to the point, four years on and the paint has signs of wear around the main foot fall areas, the odd scratches around the bike bench (I leave one of the motorbikes sat on it), and discernible tracks from the modern being reversed in and driven out, but well worth the work. So I would recommend it to anyone, yes hard work at the time, but well worth it. _________________ KA
Better three than four. |
