Joined: 30 Apr 2013 Posts: 4174 Location: The Somerset Levels
Posted: Fri Feb 20, 2015 10:53 am Post subject: Spray Cans? |
Got to spray a few smaller metal parts inside the cab of my lorry, window surrounds / dash panel etc. I thought I might just use rattle cans instead of loading the spray gun up.
Any thoughts or even brands that may be worth a look at? |
Joined: 23 Nov 2007 Posts: 4240 Location: South Cheshire
Posted: Fri Feb 20, 2015 11:06 am Post subject: |
I have found they vary in quality quite significantly. The best ones (I have found) are the ones made up at the local paint shop, you know exactly what paint is going in, they are manually pressurised and cost a fraction of the ones sold in Halfords and the like.
You can also have them made up with fade in thinner which will assist in blending to existing paintwork.
I think my local paint supplier charges about £4 for a can
bob2
Posted: Fri Feb 20, 2015 12:09 pm Post subject: |
Agree with Dave, have used both what he mentioned for quick touch ups and cans sold at ironmongers and the like and though not bad, I tend to prefer the ones from motor paint shops.
You can have even 1k or 2k spray cans nowadays whereas they have a small button at the bottom which you press to release the hardner and then shake well.
Drawback is the paint left will be destined for the bin as it goes rock solid if unused!! |
D4B
Posted: Fri Feb 20, 2015 2:06 pm Post subject: |
Yes I agree also! The best aerosol I have ever used was mixed up to a colour of my choosing by these people.
They will send them to you if you order from their website, highly recommended
I am not associated with them, just a very happy customer.
http://www.express-paints.co.uk/ |
Posted: Sat Feb 21, 2015 6:10 pm Post subject: |
I once did a "cheap" repair job for a work colleague on his Mini. I bought the (black) paint in a rattle can from Halfords. It had the correct number for the car so I felt confident. When finished, the paint job looked good. Very good. At least it did in the daylight.
It was only when we filled up under the artificial lights of the petrol station that the new paint showed up as a completely different shade from the rest of the car!
I was embarrassed, to say the least, and re- did the paint properly. |
peppiB
Posted: Sun Feb 22, 2015 11:30 am Post subject: |
I have a full car sprayed with rattle cans. Although not brilliant it looks a lot better than the hash of a job done by a so called 'professional' Couldn't complain because of the heavies that appeared. They have since been raided by armed police and closed down.
I bought the colour matched paint mail order from
www.jawel.co.uk
I have no connection with that company but have used them for years. Their rattle cans are fitted with 'pro' spray nozzles which give broader coverage than accessory shop ones.
When health/funds permit I will give her a final top coat with the spray gun
(11 cans gave the whole car 2 reasonable coats) |
goneps
Posted: Mon Feb 23, 2015 12:41 am Post subject: |
When I lived in South Africa aerosols of Duco (nitro-cellulose lacquer) were sold by one of the supermarket chains. As the Morris had been painted with Duco when restored I've used the black aerosols for various touching-up over the years, and indeed used them to respray various smaller parts such as headlamps and even the entire rear apron following repair.
Duco's so easy to work with, and imperfections are easily polished out with Brasso. A decent clip-on handle/trigger makes aerosols a lot easier to use.
Richard |
Posted: Sat Feb 28, 2015 5:15 pm Post subject: |
Well, as the dashboard is silver I took a chance and ordered some cans. Two good coats later and I am quite pleased with the result. They weren't the cheapest or the most expensive, on smaller items I will probably use them again. |
Posted: Sat Feb 28, 2015 7:30 pm Post subject: |
When it comes to buying paint I'd urge you to use the small local paint supplier...paint costs a lot to post or ship because it's relitavley heavy, buying on line will be pricey, and they can only mix to a formula (unless I suppose one sends them a sample).. The final reason is that there is quite a big margin in paint........so if in the interests of saving paper & forests you happen to mention that a recipt is not required the paint supplier will be able to discount that the price , I bought some aerosols today 4x400mL cans for £15 all mixed colours.
I do like to be environmentally friendly
Posted: Sun Mar 01, 2015 9:54 am Post subject: |
ukdave2002 wrote: | ...so if in the interests of saving paper & forests you happen to mention that a recipt is not required the paint supplier will be able to discount that the price  |
Some people nowadays may, however, need to be reminded that for such an arrangement to work it is necessary to pay for the paint with untraceable cash - cards are out as they leave a papertrail...
ukdave2002 wrote: |
+1  |
Posted: Mon Mar 02, 2015 10:31 am Post subject: |
I'd like to use a local supplier but unfortunately we don't have any round here anymore. I will probably end up travelling a little further afield to chat to a supplier in person rather than have things posted. |
