Mistydog Guest
Posted: Mon Aug 13, 2007 9:35 am Post subject: Side Opening Bonnets |
Recently I came across a problem dismantling the bonnet of the Austin 10 I am restoring. I could not remove the centre bar in the hinge. It probably had been touched for 70 years. When eventually I could move it a bit, I found I did not have anything of the right diameter or length to ream it out. After dousing it in penetrating oil, I attached the end of it in the chuck of a variable speed drill. Presto, I was able to remove it easily and without any damage. |
buzzy bee Guest
Posted: Mon Aug 13, 2007 10:46 am Post subject: |
Good tip!
