Morris 8 Series 2 - Master cylinder
GAZ5855
PostPosted: Tue Mar 31, 2015 10:54 am    Post subject: Morris 8 Series 2 - Master cylinder Reply with quote
Hi all, Newbie here, I have just removed my master cylinder on my 1937 morris 8 series 2 and wish to replace the seals, I would be very grateful on some information on how to take the cylinder apart to tackle this, thanks in advance. Gary Rolling Eyes
PostPosted: Tue Mar 31, 2015 3:51 pm    Post subject: Reply with quote
Hi Gary and welcome Smile a few of us 8 owners are on the forum
Remove circlip ; 14 whilst taking the pressure of it by pushing on to the piston with the rod :18 or a screwdriver.
Then with the circlip removed slowly take the pressure off the piston. Smile
GAZ5855
PostPosted: Tue Mar 31, 2015 4:58 pm    Post subject: Cheers Dave Reply with quote
Thanks so much Dave, though I can't see a circlip? Did they all have them?
goneps
PostPosted: Wed Apr 01, 2015 1:31 am    Post subject: Reply with quote
Something must be preventing the piston from popping out under spring force. If the unit is still mounted on the chassis, I hope it's not merely restrained by the pushrod (18 on the diagram).
Richard
Rosco663
PostPosted: Thu Apr 02, 2015 7:30 am    Post subject: Reply with quote
Gidday Gaz,
Welcome to the forum Very Happy
Both Dave and Richard are correct. Hopefully the following will help to identify the part (H45) in question. Once parts H41 - H48 are inserted in the correct order as per the schematic. The circlip is housed in the machined groove of the Barrel and Supply Tank (H38). The circlip goove is found on the left side of this part as per the schematic.
I have a Series I and the circlip on mine didn't have the Internal Circlip plier holes as per Dave's schematic but champhered ends - I replaced it with a conventional circlip as part of the rebuild.
Following is a cut away of a similar single circuit master cylinder. Make sure all the parts a scrupulously clean. The parts and cyliner bore are very easy to gat clean but the actual reservoir on the Lockheed Master Cylinder is very hard to access (unless you desolder everything). But no debris should be present - at all Exclamation Pay particular attention to the Compensating Port if this gets blocked the brakes can lock on Exclamation
Good luck with your project. Put up some pictures, I'm sure they would be appreciated by all.
Rosco
ka
PostPosted: Fri Apr 03, 2015 7:01 am    Post subject: Reply with quote
Do you have any thoughts on the brake cylinder rebuild grease that is available?
KA
Better three than four.
Penguin45
PostPosted: Fri Apr 03, 2015 10:21 am    Post subject: Reply with quote
Red rubber grease is what you want.
P45.
goneps
PostPosted: Fri Apr 03, 2015 10:28 pm    Post subject: Reply with quote
Never used rubber grease myself, but on the Morris Register forums there have been adverse comments from those who have, claiming that it congeals over time and clogs up the action of the pistons. Could it be that too much was used?
I've just reconditioned the slave cylinders on my Eight and did it the old-fashioned way, lubricating the cups with a smear of brake fluid.
Richard
ka
PostPosted: Sat Apr 04, 2015 6:26 am    Post subject: Reply with quote
Yes I have always just lubricated with brake fluid, but just wondered.
KA
