Dobbin
Joined: 15 May 2013 Posts: 67 Location: Central Scotland
Posted: Thu Jul 09, 2015 6:36 pm Post subject: Minder aftermarket car alarm / immobiliser |
| Does anyone have any information or circuit diagrams for an after market car alarm / immobiliser system made by a company called 'Minder' during the eighties or nineties? A friend has one and we suspect it's causing the car to intermittently shut down. Any information would be appreciated to assist our diagnosis of the problem. |
Greg
Posted: Sat Jul 11, 2015 4:43 pm Post subject: |
Hi, if you trace the alarm/ immobiliser loom to where the circuit cuts are, just temporarily bridge them back together with short lengths of wire, insulate the connections this will basically bypass the immobiliser. This way you can see if the fault is with the security system without removing it all.
If it turns out to be some other problem, the temporary links can be removed, re-insulated and still used.
Hope this makes sense
All the best
Greg |
Dobbin
Posted: Mon Jul 13, 2015 7:49 pm Post subject: |
Greg, many thanks for your reply and you are 100% correct. This would certainly discount connection issues and possibly the immobiliser itself but what I am looking for is a diagram of the immobiliser so that I can fault find on this to see which component it's isolating. Possibly my original question wasn't clear. Since my original post we have found a new unused but untested alarm on good old eBay and we will use this as the starting point so that we can see what goes where.
Thanks again |
Greg
Posted: Mon Jul 13, 2015 9:39 pm Post subject: |
No problem. I hope you manage to sort the problem soon
All the best
Greg |
