Posted: Thu Sep 17, 2015 9:02 am Post subject: Can you do your own painting. |
I always got a pal or a local garage to do any painting for me. When I got the Estate I took it to a garage who came "highly recommended" What a mess orange peel effect all over. I only ever had a go with an aerosol but wasn't very good at it. Not my forte I am afraid. If you can weld and paint you are quids in. I just wondered who else can paint their own car. _________________ The Clan Chieftain |
Joined: 30 Apr 2013 Posts: 4170 Location: The Somerset Levels
Posted: Thu Sep 17, 2015 11:56 am Post subject: |
I am just getting ready to spray my vintage lorry, its taken an age to prep but is saving so much money giving it a try myself. _________________ Various Rootes Vehicles. |
Posted: Fri Sep 18, 2015 12:39 pm Post subject: |
Dave,
I have never read your thread on the MGA before, looks great and some good tips along the way. _________________ Various Rootes Vehicles. |
Posted: Fri Sep 18, 2015 5:23 pm Post subject: |
I don't usually blow my own trumpet but when this was finished in cellulose it buffed up better than new and I felt a great sense of satisfaction from doing it myself.
I have done other cars but somehow they never seem to reach this standard. I am not sure, but I wonder if the paint these days is quite as good as it used to be. They don't want you to use nitro but nothing else is suitable unless you have all the gear.
* Dave, your car looks absolutely fabulous  |
Posted: Fri Sep 18, 2015 6:43 pm Post subject: |
Ray White wrote: |
Thanks Ray...what I worked out (which I suspect Ray also worked out) is that to get a great result you don't have to be good a painting / spraying, you just have to put the elbo grease in afterwards
Which I discovered is also how many "pro" painters operate......
Joined: 25 May 2011 Posts: 2701 Location: South Cheshire
Posted: Fri Sep 18, 2015 6:57 pm Post subject: |
I've just started putting some colour on my project. Results are, shall we say, variable. But it buffs up quite well afterwards. I'm getting used to things by painting the inside of the bonnet and edges of doors before getting onto bits that will be visible later on. |
Ellis
Posted: Fri Sep 18, 2015 9:20 pm Post subject: |
I am very impressed at UKdave2002 and Ray White's skills.
I do my own preparation whenever possible such as removing all old paint, applying phosphate preservative coatings and even etch and ordinary primers but do not have the confidence (or skill probably) at applying colour topcoats. _________________ Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet |
Posted: Fri Sep 18, 2015 9:25 pm Post subject: |
I did the front end of the Singer myself, finish is fine..colour match isn't great due to the origional paint base being unavailable now.
Just takes a bit of trial and error
Kev |
Posted: Fri Sep 18, 2015 10:06 pm Post subject: |
Kevin. I think the classic Singer has a front end that would melt the hardest of hearts - but in that colour it is simply drop dead gorgeous.
If you don't mind me asking, who is your paint supplier.? |
Posted: Fri Sep 18, 2015 10:19 pm Post subject: |
Ray White wrote: | Kevin. I think the classic Singer has a front end that would melt the hardest of hearts - but in that colour it is simply drop dead gorgeous.
I used a company in Stoke, Dave put me onto them. Great service but as the base isn't available we struggled for a match. I'm planning a repaint in the next few years.
Kev |
goneps
Posted: Fri Sep 18, 2015 10:37 pm Post subject: |
ukdave2002 wrote: | ...to get a great result you don't have to be good at painting / spraying, you just have to put the elbow grease in afterwards.
I'll second that. While I've neither the experience nor the facilities to do more than occasional touching up, the Tourer was painted in Duco (cellulose) when restored, and when I lived in South Africa one of the major supermarket chains sold Duco in aerosols. Consequently I've done some serious touch-up work on the wings and even completely resprayed the rear valance, rubbing down with Brasso for an excellent result. A plastic clip-on trigger makes aerosol work a lot easier.
Richard |
OuBallie
Posted: Sun Sep 20, 2015 11:41 am Post subject: |
goneps!
Oh man you have brought back memories mentioning Duco!
Used that on all my cars, plus on my Kyalami racing 105E.
Cannot decide whether to coach paint or spray cellulose on the Austin Seven.
Never having tried coach, will need to give it a try first.
Getting rid of orange peel is straight forward:
Rub down with very fine wet&dry, then polish. Magic.
Geoff - Learned that trick when I painted my miniature steam locomotive. _________________ Too many hobbies, not enough time!
1935 Austin Seven Ruby ARQ
1957 Austin A35 2-door
1967 Morris Minor 2-door
Model Engineering |
peppiB
Posted: Sun Sep 20, 2015 3:24 pm Post subject: |
OuBallie wrote: |
I found that coach paint (sprayed, not brushed) gave an artificial look opposed to cellulose
First cellulose painting (by me)
Then my efforts with coach paint
Billf
Joined: 01 Jul 2011 Posts: 202 Location: North Cyprus.
Posted: Mon Sep 21, 2015 12:24 pm Post subject: |
I brush painted my K2. Lot's & Lot's of prep work first though. Fillers Primer and undercoats all rubbed down between coats, and using Valsper Trade Paints. And lot's of masking tape. Using a very soft 3" brush and choosing you areas and work very quickly gently laying the paint off. Then more elbow grease with really fine Wet & Dry. And more elbow grease with T Cut. Then more elbow grease with polish. At my first show at the North East Military Club in Durham, i was told by some ex NFS fella, that should be painted grey not green. I suppose it did help as i was a time served Decorator.
(I used Valspar Paint not Brolac)
