Talking of Screwdrivers.
PostPosted: Thu Oct 08, 2015 7:37 am    Post subject: Talking of Screwdrivers. Reply with quote
Prompted by the lively debate about Engine Oil, how about the humble screwdriver.
Paint Can opener.
Lever.
Punch
are just a few of their uses. However I do have a good set that are used only for their intended purpose. (Most of the time)
Wink
PostPosted: Thu Oct 08, 2015 8:08 am    Post subject: Reply with quote
Its not the first time I have had to puncture through an oil filter to get it off because someone had screwed it on too tight
The Clan Chieftain
PostPosted: Thu Oct 08, 2015 8:51 am    Post subject: Reply with quote
Along with the hammer, the most useful tool in the toolbox Laughing
PostPosted: Thu Oct 08, 2015 10:13 am    Post subject: Reply with quote
I find an ordinary screwdriver an invaluable tool for opening those f****** horrible ring pull food cans. Seriously, what on earth was wrong with a can opener?
BigJohn
PostPosted: Thu Oct 08, 2015 4:49 pm    Post subject: Reply with quote
Villians ignition key of choice back in the 80's
PostPosted: Thu Oct 08, 2015 6:09 pm    Post subject: Reply with quote
Also used at the top of the door to help get the coat hanger hook past the seals in order to pop the lock button or hook the door handle.
Not needed so often for this after the invention of plastic packaging strip.
PostPosted: Thu Oct 08, 2015 6:13 pm    Post subject: Reply with quote
Re the above, I once locked myself out of a Mini, around '66, with the engine still running, I got back in by using something from under the bonnet.
What was it and how did I use it to gain entry?
PostPosted: Thu Oct 08, 2015 6:26 pm    Post subject: Reply with quote
Spare key ? Laughing
Penguin45
PostPosted: Thu Oct 08, 2015 7:11 pm    Post subject: Reply with quote
Dipstick.
PostPosted: Thu Oct 08, 2015 7:34 pm    Post subject: Reply with quote
Penguin45 wrote:
Dipstick.
Who is ?
PostPosted: Thu Oct 08, 2015 8:46 pm    Post subject: Reply with quote
The bonnet stay??
Art
PostPosted: Fri Oct 09, 2015 1:40 pm    Post subject: Reply with quote
Maybe a screwdriver you keep under the bonnet somewhere in case you lock yourself out. Laughing
The Clan Chieftain
BigJohn
PostPosted: Fri Oct 09, 2015 1:50 pm    Post subject: Reply with quote
Early Mini? probably your hands, you just reached in and peeled the rusty bulkhead away ......
PostPosted: Fri Oct 09, 2015 2:35 pm    Post subject: Reply with quote
One person has "what" right, but how was it used?
PostPosted: Fri Oct 09, 2015 2:56 pm    Post subject: Reply with quote
Push the dipstick between the two sliding windows, press the little chrome button catch & open the window. (This assumes the catches haven't been reversed).
2002 MINI Cooper 'S'
