Morris 8 Headlights
Ralphg
PostPosted: Sat Feb 13, 2016 10:20 am    Post subject: Morris 8 Headlights Reply with quote
Hi, can anyone help and tell me how to remove the reflectors from the headlights after the rim has been taken off. There seems to be some sort of clips round the edge of the reflector. Both the reflectors have been fitted incorrectly so the globes shine sideways instead of down. Thanks Ralph.
PostPosted: Sat Feb 13, 2016 12:18 pm    Post subject: Reply with quote
Which version of the 8, does it have the mechanical dipping reflectors or duel filament?
goneps
PostPosted: Sat Feb 13, 2016 2:09 pm    Post subject: Reply with quote
On the 35/Series 1/Series 2 Eights (1934-38 ), after the rim is removed there should be a sealing strip around the edge of the reflector. Peel this back and there should be a tiny screw at about the 1 o'clock position. Once this is removed the reflector can be turned to release the flanges behind it from those of the nacelle.
Richard
Ralphg
PostPosted: Wed Feb 17, 2016 9:59 am    Post subject: Reply with quote
Hi Richard, thanks for this bit of information, I've managed to get the reflectors off and found that whoever started the restoration managed to crimp the bulb holders into the reflectors in the wrong position so I've rotated the reflectors so that the bulb is correct, just had to drill new holes for the securing screw. Thanks, Ralph.
