shotblasting question
mr911er
PostPosted: Fri Feb 12, 2016 6:30 pm    Post subject: shotblasting question Reply with quote
Hi everyone
I want to clean up the engine a bit on my 1982 Porsche 911. I had a problem with the alternator recently, and have had to remove the fan and cowling, which I want to clean up, and maybe powder coat the fan.
They need blasting, but I have seen a few reports about shotblasting being too harsh - the parts are made of magnesium. No-one that I want to use seems to do beadblasting locally, so shotblasting will probably have o do.
Is it too harsh? Be interested to hear any comments
Thanks
Kevin
PostPosted: Fri Feb 12, 2016 7:23 pm    Post subject: Reply with quote
Hi Kevin
Welcome back to the forum.
I think I'd err on the side of caution personally, do you have any photos to hand showing how bad they look?
mr911er
PostPosted: Sat Feb 13, 2016 10:40 am    Post subject: Pic Reply with quote
[img]
Let's see if this works lol
Regards
Kevin[/img]
mr911er
[img]
Regards
Kevin[/img]
alanb
PostPosted: Sat Feb 13, 2016 6:29 pm    Post subject: Reply with quote
Try Aqua blasting it ideal for alloys, brass, copper, & aluminium, or more delicate items.
old tourer
Morris 8 two seater
PostPosted: Sat Feb 13, 2016 8:16 pm    Post subject: Reply with quote
I would be tempted to brush on and agitate some alloy wheel cleaner,
then jet wash it off within 5 mins, see how that goes first...... ?
mr911er
PostPosted: Mon Feb 15, 2016 10:21 pm    Post subject: Reply with quote
Aqua blasting or bead blasting may be the answer
Be amazed if alloy wheel cleaner will touch it, quite a lot of crap build up....
Anyone know does it? In north worcs
k
PostPosted: Tue Feb 16, 2016 11:49 am    Post subject: Reply with quote
Have you tried having a look on the restoration section on DDK? Lots of people restoring similar stuff, the parts they put back on always seem to be very nice and shiny.
mr911er
PostPosted: Thu Feb 18, 2016 7:38 am    Post subject: Reply with quote
Excuse my ignorance lol, but what is DDK?!!
Kevin
PostPosted: Thu Feb 18, 2016 11:12 am    Post subject: Reply with quote
Porsche restoration forum - Die Deutschen Klassiker - http://www.ddk-online.com/phpBB2/index.php - aim for the "technical" section and the restoration threads in there.
alanb
PostPosted: Thu Feb 18, 2016 1:24 pm    Post subject: Reply with quote
found this on the web.
Metal Polishing in Amblecote, Stourbridge, Black Country,
www.imperialmetalpolishing.co.uk
old tourer
Morris 8 two seater
mr911er
PostPosted: Sat Feb 27, 2016 5:42 pm    Post subject: Reply with quote
Thanks Alan's
Did phone them. Left a message, but they couldn't be bothered to reply.
In the end I took it to Worcestershire powder. Oating in pershore. The know someone who could repair the fan too, so waiting for its return know.
Cheers Kevin...
greenbeam
PostPosted: Wed Mar 02, 2016 7:53 am    Post subject: Reply with quote
I have just soda blasted some items myself and had very good results.
Small blasting units are available from fleaBay that hook up to a compressor, you fill them with sodium bicarbonate (bicarb - available in 10-20kg bags from butcher suppliers) and the stream of soda will remove paint, grease gunge, but will not remove metal (rusted or otherwise). Alloy carby bodies come up a treat, so your mag items should too.
The bicarb doesn't contain silicon, so can be done outdoors with simple dust mask, and hosing the area down dissolves the bicarb.
There is a bit of info on the web, but don't pay big $$ for a kit, the cheap ones are fine for infrequent home use. I bought mine for one job and have used it a couple of times since.
Regards,
Paul.
1963 Sunbeam Alpine Series 3
1935 Armstrong Siddeley 17HP Coachbuilt Saloon
