1948 Ford Prefect
Dave1948
PostPosted: Wed Mar 30, 2016 4:46 pm    Post subject: 1948 Ford Prefect Reply with quote
Can anyone help...Should there be a gasket on the side of the carburettor where the float chamber fits against the side of the carburettor. She runs great but when excellerate she just cuts out? It's a fordco carburettor. Rolling Eyes
Farmer John
PostPosted: Thu Mar 31, 2016 9:46 pm    Post subject: Reply with quote
Hi Dave.
No gasket there but the one on top of the bowl must be good.
Is that a different carb fitted? It may have an accelerator pump not working, watch the nozzle while opening the throttle. Best check with motor not running.
If it is the original the jets to clean are in the bottom of the bowl, one of the holding bolts will have a square end to undo the jets. Using carb cleaner is getting to be necessary at least with fuel here.
Try pulling the choke out (try different settings) to see if that will cure the fault, just to confirm that a lean mixture is the problem.
No need to go hunting vacuum leaks or spark problems right now, come back to us and we will go from there.
John
Dave1948
PostPosted: Fri Apr 01, 2016 12:49 pm    Post subject: Thanks Reply with quote
Thanks for your help. Will let you know how we go. It is the original carburettor. Wink
PostPosted: Fri Apr 01, 2016 10:05 pm    Post subject: Reply with quote
There's a gasket that fits between the emulsion block, and the float chamber, if memory serves. You access it by removing the small screws, once the chamber has been dropped out of the carb.
As FJ mentions, cleaning the jets is easy enough to do.
(I don't suppose that the points in the dizzy have closed up, have they?)
Rene
PostPosted: Sat Apr 02, 2016 6:56 am    Post subject: Re: 1948 Ford Prefect Reply with quote
Sounds familiar,with my '48 Anglia the same problem appeared and after a lot of fiddling the fuel tank outlet was rusted almost shut,there was simply not enough fuel feed to the carb float chamber for accelerating...........
Cleaned the outlet and the problem was gone.
Good luck,René
