Spark Plug Tyre Inflator. Whose idea was this?
Vintage Crank
PostPosted: Fri May 06, 2016 9:56 pm    Post subject: Spark Plug Tyre Inflator. Whose idea was this? Reply with quote
1970's Spark Plug Tyre Inflator
I'm not sure which one I find more disturbing - the idea of filling a tyre with uncombusted compressed petrol vapour or...
...the really sinister looking Chevy Nova driver!
http://www.ebay.co.uk/itm/RARE-VINTAGE-SPARK-PLUG-TYRE-INFLATOR-/322099356025?hash=item4afe9e2179:g:-SgAAOSw1DtXLJM~[/img]
Dave (Professional Procrastinator)
1927 Morris Oxford Saloon 14/28
1949 Ferguson TED20 tractor and other 1950s
1958 Series 2 Land Rover 88" and various 2a's
1969 Jaguar 420G
PostPosted: Fri May 06, 2016 10:12 pm    Post subject: Reply with quote
Here is a use for exhaust gasses.
http://www.ebay.co.uk/itm/4T-Ton-Tonne-Exhaust-Jack-Lifting-Air-Bag-Kit-Car-Van-Truck-4x4-Offroad-/191732291972?hash=item2ca4229984:g:hCQAAOSwBahVGFWU
Vintage Crank
PostPosted: Fri May 06, 2016 10:16 pm    Post subject: Reply with quote
Not so much chance of a literally explosive blowout with that one..!
1969 Jaguar 420G
PostPosted: Fri May 06, 2016 10:34 pm    Post subject: Reply with quote
I've one in the garage, untried during my ownership though
http://www.oldclassiccar.co.uk/spark-plug-pump.htm
Vintage Crank
PostPosted: Fri May 06, 2016 10:44 pm    Post subject: Reply with quote
I imagine it wouldn't be much use with a 4 cylinder engine unless you were planning on just cranking it over for ages, but I've had plenty of V8s that would happily run with one or more cylinders out of action. Looks like an American advert so I guess it was fine for their engines in the '70s.
1969 Jaguar 420G
PostPosted: Sat May 07, 2016 12:52 am    Post subject: Reply with quote
Could he be the "Phantom Wing Feeler" mentioned in another section ?
PostPosted: Sat May 07, 2016 9:02 am    Post subject: Reply with quote
Not very helpful if you use tubes but there's always....
https://www.youtube.com/watch?v=SqIBhSJI3og
Peter Laughing
PostPosted: Sat May 07, 2016 10:50 am    Post subject: Reply with quote
As I understand them, the pressure created by the engine's piston is transferred to pressure within the inflator, in such a way that petrol/air mix does not enter the tyre.
If you try one out, and smell the air from the end of the hose, there is no petrol smell.
I have used various ones from time to time, the first over 50 years ago.
PostPosted: Sat May 07, 2016 11:17 am    Post subject: Reply with quote
That kind of implies a diaphragm or piston and an inlet valve but there doesn't appear to be either in VC's photo.
BigJohn
PostPosted: Sat May 07, 2016 12:32 pm    Post subject: Reply with quote
I have a couple of spark plug tyre inflators, but I also have an exhaust powered car vacuum cleaner.......
PostPosted: Sat May 07, 2016 1:12 pm    Post subject: Reply with quote
Quote Big John: "I have a couple of spark plug tyre inflators, but I also have an exhaust powered car vacuum cleaner....... " /Quote
Does it blow as well ?
Rolling Eyes Wink Embarassed
BigJohn
PostPosted: Sat May 07, 2016 6:40 pm    Post subject: Reply with quote
Only after a curry Shocked
norustplease
PostPosted: Sat May 07, 2016 9:14 pm    Post subject: Reply with quote
About forty years ago, I equipped a Land Rover for a desert expedition in North Africa and one of those tyre inflators was a compulsory piece of kit. As said elsewhere in the thread, it draws in fresh air and does not introduce explosive vapours into the tyre.
1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV
JohnDale
PostPosted: Thu Jun 02, 2016 3:48 pm    Post subject: Reply with quote
I've had one since I had my first car(no Halfords plug in ones then) & used it on many different sized engines without problems. It still goes in the car even now. Great look on a guys face in the middle of nowhere when I blew up his flat spare tyre - bet he checks it now,cheers,JD
1976 Ford Granada Ghia.
PostPosted: Thu Jun 02, 2016 11:29 pm    Post subject: Reply with quote
Always considered them a bit of a challenge for a Jowett twin!
