zagatoman
Joined: 31 Aug 2010 Posts: 55 Location: Sutton, Surrey
Posted: Sun Jun 19, 2016 6:02 pm Post subject: 1936 Morris 8, 6v starter spinning but bendix not engaging |
Hi all, had an intermittent problem for the last few months that has been getting worse and now has completely failed.
I have a 1936 Morris 8 with 6v electrics, and for the last few months occasionally the starter spins without throwing out the bendix and not engaging the engine but sometimes is fine. Today I took the starter off and placed on the bench and connected 6v power and found the starter spins but not fast enough for the bendix to throw out. The bendix is clean and is free to move up and down the spiral shaft with minimal effort when moved by hand.
The question is to you very knowledgeable people is could it be something simple and I could sort out or something more serious for a professional?.
Any advice would be greatly appreciated, thanks, Paul
 _________________ Enthusiastic amateur classic car nut. |
Joined: 16 Oct 2008 Posts: 1168 Location: Upper Swan, Western Australia
Posted: Sun Jun 19, 2016 8:29 pm Post subject: |
I have two cars with 6v electrics and when I experience starters that will not go fast enough to engage the Bendix, my first check is the battery. Is it fully charged? It can also be a loose connection on the supply cables, or even a bad contact in the switch. But I would check the battery first.
BTW, I love the car!
Keith |
goneps
Posted: Mon Jun 20, 2016 4:08 am Post subject: |
First step is to follow Keith's advice and make sure the starter is getting plenty of juice. Since you state that the Bendix is clean and free, we can eliminate the possibility of leaking engine oil gumming up the works, which is a fairly common cause of non-engagement.
Does the armature spin freely when twirled by hand? I had what I thought was a tired starter, but in fact the pressed steel rear cover plate that holds the brushes and shaft bush had been distorted by some ham-fisted previous owner, so that the bush axis was not perpendicular to the plane of the plate. Consequently, when the long bolts were tightened the bush was binding on the shaft. The starter had enough trouble trying to turn itself, let alone a cold engine. This also placed undue strain on the battery.
The above only applies if your starter is the early type with the cable-operated switch mounted on top. Later models have the switch mounted on the end plate, which is a zinc or aluminium casting. In this case the brush connections are riveted, and corrosion can occur within the riveted joints. The only cure is to drill out the rivets so that the assembly can be thoroughly cleaned.
Richard |
bjacko
Joined: 28 Oct 2013 Posts: 534 Location: Melbourne Australia
Posted: Mon Jun 20, 2016 8:05 am Post subject: Slow Starter |
| Make sure the earth connections are not rusted. Easy way to check is use a jumper lead direct from the earth on the battery to the starter body. If it spins quicker you have a bad earth. |
Posted: Mon Jun 20, 2016 2:22 pm Post subject: |
Re "connected 6v power"
Was that the car battery power ? or from a battery charger or similar. |
bjacko
Posted: Tue Jun 21, 2016 5:57 am Post subject: Slow Starter |
| From the car battery. |
Posted: Tue Jun 21, 2016 12:53 pm Post subject: |
| So if a fully charged battery and a bench test has the same result then something in the starter could be the problem, or a faulty battery, that prevents it from providing the current required. |
zagatoman
Posted: Tue Jun 21, 2016 3:58 pm Post subject: |
Hi all, thanks for everyone's advice, very helpful. Yes, the battery is a new 404 and fully charged. All the wires are strong and rust free so the problem must be inside.
I have now taken it over to a specialist in Brixton, Robson & Francis Rewinds Ltd, what a fantastic place. He will test it out and report back with the problems, lets hope not expensive ones.
I have included a couple of photos of the offending Lucas M35G starter.
Paul
goneps
Posted: Tue Jun 21, 2016 4:55 pm Post subject: |
That's the oddest M35 starter I've seen. What is the object that looks like an offset pulley between the switch and green-painted body? Never see the like before.
Richard |
zagatoman
Posted: Tue Jun 21, 2016 6:19 pm Post subject: |
Hi Richard, The grey block you pointed out holds the large separated copper contacts that the cylindrical switch when operated pushes down onto with with a circular copper plunger to make the circuit and spin the starter.
Hope that helps, Paul
Posted: Tue Jun 21, 2016 6:43 pm Post subject: |
| Could very well be lack of conductivity on the switch contacts, due either to a weakness in the mechanics that push the contact together, or age related degradation caused by the unavoidable arcing that occurs. |
goneps
Posted: Tue Jun 21, 2016 11:08 pm Post subject: |
Indeed—I believe his type of starter switch may be more susceptible than the earlier top-mounted type. Or, as mentioned earlier, corrosion within the riveted brush connections.
Richard |
bjacko
Posted: Wed Jun 22, 2016 6:04 am Post subject: Morris 8 Starter |
| This model starter and starter switch were fitted to the late Ser II and early (pre-war) Ser E cars. |
zagatoman
Posted: Fri Jul 01, 2016 4:26 pm Post subject: |
Hi all, my starter motor now all sorted thanks to Robson & Francis Rewinds of Brixton South London, fantastic job. This place is proper old school and very professional friendly and knew everything about anything, they also do a collection and delivery service.
www.robsonandfrancisrewinds.co.uk _________________ Enthusiastic amateur classic car nut. |
goneps
Posted: Fri Jul 01, 2016 11:48 pm Post subject: |
So what was the problem, according to the experts? It would be useful to know.
Richard |
