standard 10
robo0121
PostPosted: Thu Jul 21, 2016 8:03 pm    Post subject: standard 10 Reply with quote
Hi has anyone on here got any info on the standard 8 or 10s ie what other wheels would fit.?/just seen one on ebay and it has cosmic alloys on and I think something like that is needed to pep it up a bit...grateful for any suggestions and thanks
PostPosted: Thu Jul 21, 2016 8:38 pm    Post subject: Reply with quote
Anything from the Triumph Herald/Vitesse/Spitfire/GT6 range is a straight swap; in fact the early Triumph Herald wheel is identical. So any after-market wheel designed for the Triumph range is suitable. Come to think, you can also add Triumph Dolomite and Morris marina to that list.
robo0121
PostPosted: Thu Jul 21, 2016 9:16 pm    Post subject: Reply with quote
wicked thanks a million for your reply
PostPosted: Thu Jul 21, 2016 9:21 pm    Post subject: Reply with quote
Is that the red/black one?
As MikeC says, Herald/Spitfire wheels will go on, as will Dolomite ones although I'm trying to remember if the offset on Dolly wheels was slightly different than those fitted to Heralds etc?
robo0121
PostPosted: Thu Jul 21, 2016 9:44 pm    Post subject: Reply with quote
Thanks Rick yes it was the red and black one I was referring to.if it does come to mind that the dolomite wheels are different could you please post it.many thanks
PostPosted: Thu Jul 21, 2016 9:59 pm    Post subject: Reply with quote
I would go for one of the others on Ebay at the moment. Two Standard Tens, both under 1000 UKP, both in a more original condition. And a 10 does have a slightly bigger engine and a proper bootlid.
PostPosted: Fri Jul 22, 2016 10:29 am    Post subject: Reply with quote
The Standard Ten is a gorgeous little car. I owned a panel van version for several years in the early sixties. My wife and I did a lot of our courting in it. We used it to explore Southern England. In fact I wouldn't mind another one now!
Keith
PostPosted: Sun Jul 24, 2016 7:23 am    Post subject: Reply with quote
I like them a lot too, I ran a Standrive Ten for some time, and later a Companion (estate). Like Keith, I'd own another one tomorrow, and would probably be looking for one now had I not bought my MM as a (hopeful) regular user.
