Joined: 20 Aug 2008 Posts: 1476 Location: Netherlands
jp928
Posted: Sun Jul 24, 2016 1:51 am Post subject: |
It certainly is! I think this sort of case is actually worse than a completely missing loom in many ways. While my car has a much simpler layout (1926 Rover), once I have absorbed the wiring diagram I can make it as neat as possible with no distractions, and modernize parts to make it easier to maintain. You will need to work out whats a fudge to bypass a problematic piece of wiring, and whats leftover from a previous owners additions/mods etc before you can resolve how to fix it. Try getting a look at the engine bay of the same model that hasnt been monstered, or even get a new engine bay loom.
jp |
Posted: Sun Jul 24, 2016 10:52 am Post subject: |
| Looking at that I'm pretty sure it would be easier - and certainly more reliable in the long run - to rip it all out and start again. Why do some people think that kind of mess is acceptable? |
peppiB
Posted: Sun Jul 24, 2016 3:45 pm Post subject: |
Must admit to being a culprit for something similar. About 3 years ago I couldn't start the landcrab and traced the fault to a broken wire in the loom. I ran a new replacement wire from the ignition to the coil and it worked fine.
I just haven't got around to incorporating said wire into the loom. It stares me in the face with its bright orange colour every time I lift the bonnet - but it works and if i disturb it, it may not work
Only me looks under the bonnet so I am just leaving it for now. Anyway it is painful and awkward doing such jobs from a wheelchair! |
jp928
Posted: Sun Jul 24, 2016 11:03 pm Post subject: |
IMHO your crime is more than cancelled out by your effort in diagnosing and correcting the fault on your own. What would pull you well into the positive side of the ledger would be, next time you look under the bonnet, fit a label to the offending wire indicating why it is there! Then Nobody down the track should complain.
See if you can find on old Aussie bush movie called 'Bush Mechanics'.....
https://www.youtube.com/watch?v=wspwBcuOZFg
jp |
