UKdave2002 Guest
Posted: Wed Sep 19, 2007 1:23 pm Post subject: Fitting Tyres |
I have to fit some new tyres at the weekend, is it dot by the valve or opposite?
Ta Dave |
Posted: Wed Sep 19, 2007 7:50 pm Post subject: |
UK, as you have helped me today, one good turn deserves another.
If you are meaning the (usually) red dot, it should go nearest the valve, as it is the lightest point of the tyre.
UJ |
UKdave2002 Guest
Posted: Thu Sep 20, 2007 6:55 pm Post subject: |
UJ
yep, tis the red dot. thanks for this.
UKdave2002 Guest
Posted: Thu Sep 20, 2007 7:10 pm Post subject: |
I have a "manual tyre fitter" (read replace pneumatics with some elbow grease!)which you are more than welcome to use/ borrow. Breaking the bead is the hard bit which this thing does!
UKdave2002 Guest
Posted: Fri Sep 21, 2007 8:04 am Post subject: |
Simple to use, I'll stick a pic on , its really just a frame that supports and holds the wheel horizontally, so that you can use a large lever to fit or remove the tyre. |
47p2 Guest
Posted: Thu Oct 04, 2007 11:23 am Post subject: |
Here is a good link for the Tyre Bible |
