winchman
Posted: Mon Aug 15, 2016 5:38 am Post subject: Rusty motor bike keeping the patina |
I have a rusty old 1960s Mobylette, its almost complete and we would like too get it running but leave the rusty patina so how should I treat it?
 _________________ It will come in handy even if you never use it. |
Posted: Mon Aug 15, 2016 7:27 am Post subject: |
I used to have the same model.
It should be possible to lose the red rusty look, then I'd either go over it with a lightly-oiled rag (although your clothes might not like that option) or else a proper wax in a tin - not the paste stuff. Some also use linseed oil.
One trick I was given to lose the red rustiness, was to go over the paintwork with one of those two-sided pan scrubs, with a 50% mix of water and bleach. Obviously try a small area first, but it tends to turn the rusty bits grey which looks better (IMO), before waxing or oily-ragging. Sometimes using a polish over the affected areas, such as Mer, has the same effect.
winchman
Posted: Mon Aug 15, 2016 7:40 am Post subject: |
Thanks
How do you think I should un seize it?
I am missing the nut that holds the forks on but other than that it looks complete _________________ It will come in handy even if you never use it. |
DM
Joined: 21 Dec 2008 Posts: 214 Location: North Cornwall
Posted: Mon Aug 15, 2016 8:07 am Post subject: |
Some have used Owatrol to protect a rusty/ patinated vehicle, It's intended for use on garden furniture.
The rust absorbs it and it dries to a matt finish |
winchman
Posted: Fri Aug 19, 2016 6:36 pm Post subject: |
Thanks for your help, after a lot of thought we have decided to sell it as we just have too many unfinished projects _________________ It will come in handy even if you never use it. |
