What water do you use for your pre-war car?
Rich5ltr
PostPosted: Fri Sep 02, 2016 2:56 pm    Post subject: What water do you use for your pre-war car? Reply with quote
Assuming most of you use water and blue anti-freeze what water do you use? Tap water, rain water or deionised water? Must confess I've used tap water until now but I thought perhaps I should use rain water from the butt. Then someone suggested that's not PH balanced. Does that matter, what's best?
Thoughts? Rich...
Ellis
PostPosted: Fri Sep 02, 2016 5:39 pm    Post subject: Reply with quote
I don't own a pre war car but ever since my Triumph Dolomite Sprint and Stag days I have used, still do, distilled water and Bluecol in a 50/50 mix.
I use the same mix in the Land Rover 2a and the Jaguar Mark 2..
Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet
PostPosted: Fri Sep 02, 2016 6:55 pm    Post subject: Reply with quote
If you live in an area where your kettle furs up I would suggest not using tap water.
Rich5ltr
PostPosted: Fri Sep 02, 2016 7:37 pm    Post subject: Reply with quote
Indeed, not just pre-war but all classic cars. Yes, not tap water in my area but I was considering rainwater. on another tread deionised seems to be the favourite.
PostPosted: Fri Sep 02, 2016 10:38 pm    Post subject: Reply with quote
Tap water here in Cheshire, it's ok for batteries as well..
PostPosted: Sat Sep 03, 2016 9:57 am    Post subject: Reply with quote
My water supply is either rain off the roof collected in a 5,000 gallon tank, or a supply by pumping from the river.
The river water is fine for toilet flushing, garden watering and filling the cattle trough, but the rain water is used all other purposes- drinking, washing, cooking, and naturally to top up the radiators of the 'fleet'. No need for antifreeze here, but I do add corrosion inhibitor.
PostPosted: Sat Sep 03, 2016 10:09 am    Post subject: Reply with quote
The water round here is not soft but neither does excessive hard scale build up. I have always used tap water including the pre-war Rover and land Rovers
Rover P2
Morris Mini Traveller Mk2
Castellated nut
PostPosted: Sat Sep 03, 2016 7:17 pm    Post subject: Reply with quote
I use water from a dehumidifier. I'm hoping that since it is condensed water vapour it must be closely related to distilled water!
PostPosted: Sun Sep 04, 2016 10:18 pm    Post subject: Reply with quote
I have always used tap water in all of our vehicles.
lowdrag
PostPosted: Mon Sep 05, 2016 4:32 pm    Post subject: Reply with quote
Very hard water here. Locals advise adding a bit of white vinegar, which is something I use in the washing machine, dishwasher, kettle and coffee maker to de-fur. it's cheap and works wonders.
emmerson
PostPosted: Mon Sep 12, 2016 5:03 pm    Post subject: Reply with quote
Tap water, wherever I am. That's all I drink too*, and I'm not yet dead!
*(except for beer and whisky, of course!)
