sourcing a propshaft u/j gaiter.
PostPosted: Tue Sep 06, 2016 5:51 pm    Post subject: sourcing a propshaft u/j gaiter. Reply with quote
I am trying to locate a suitable rubber gaiter to fit the prop shaft of my '26 Dodge Brothers. The fitting size is 2.5" x 2.2" (63.5 x 55.88 mm). The length is less important. I am hoping that someone here can point me in the right direction. Is there a bellows type gaiter that with a little modification might suit this application?
If you have something that I could use please help.
Many thanks
Ray.
PostPosted: Tue Sep 06, 2016 6:50 pm    Post subject: Reply with quote
I've seen "universal" steering rack gaiters that come with a stepped effect at each end, you cut them to the desired diameter for your rack. I can't imagine that a rack one would be large enough to cope with that diameter though as the steering arm end tends to be much smaller. Is there a similar CV boot that has adjustable ends?
Failing that could you make something out of a length of suitable inner tube, cut generously to allow some play and fixed at each end with zip clips? I've got some cycle inner tube over my steering arm / track rod ends so I can grease them and stop the water getting in, though they don't rotate in the same way of course.
PostPosted: Tue Sep 06, 2016 7:01 pm    Post subject: Reply with quote
I'm afraid the "universal" types are too small as you suggest.
I did see a Land Rover gaiter that looked promising but they never give any sizes!!
http://www.ebay.co.uk/itm/LANDROVER-SERIES-2-2A-3-PROPSHAFT-RUBBER-GAITER-276484-/222212110578?hash=item33bcdfb8f2:g:1BIAAOSw4HVWCQqJ
As to your suggestion of an inner tube; I had hoped to find a gaiter that fitted seamlessly so that the grease stayed in. It is a torque tube with sliding trunnion and so doesn't rotate but it has always leaked from a home made dust jacket. The original "boot" would originally have been made of leather.
Ashley
PostPosted: Tue Sep 06, 2016 9:49 pm    Post subject: Reply with quote
I expect it should be leather in which case Wefco will help you.
PostPosted: Tue Sep 06, 2016 10:31 pm    Post subject: Reply with quote
Thanks for the suggestion, Ashley but I had only ever heard about their spring gaiters which are a thing of great workmanship but at £228 for each corner they don't come cheap! I don't intend paying more than I need so if I eventually have a leather gaiter made for this torque tube I will probably have our local saddler make one or have a go myself.
As it happens, this evening I have found a suitable bellows on Ebay. Should be better than used hitherto.
http://www.ebay.co.uk/itm/201636921704?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
PostPosted: Wed Sep 07, 2016 12:55 pm    Post subject: Reply with quote
If you suspect that a Landrover part will do the job I suggest you talk to Dingocroft. I have no connection with them other than as a customer, but they are helpful and don't just demand a model number, chassis number etc.
Dipster
PostPosted: Wed Sep 07, 2016 1:16 pm    Post subject: Reply with quote
I can also suggest Famous Four who are also an independent garage specialising in Land Rovers. Their parts department have served me well over many years. They are very helpful people.
JohnDale
PostPosted: Thu Sep 08, 2016 4:35 pm    Post subject: Reply with quote
Hi Ray, how about tractor/combine drive shafts as a possibility for your gaiter
Most of the shafts have gaiters which would be more of a size for your job.
A chat to a tractor sales partsman might be of help,cheers,JD.
1976 Ford Granada Ghia.
PostPosted: Thu Sep 08, 2016 4:51 pm    Post subject: Reply with quote
Many thanks for the various suggestions. I have opted for the trailer bellows type because they seem to have more movement in them. Now I have removed the rear springs from the axle I have been able to separate the torque tube from the transmission so will be able to fit the bellows when I reassemble the drive train.
In case anyone wondered why I didn't just knock out the spring eye bolts, some clown has fitted the body of my car so that the access holes don't line up with the spring eyes as they were designed to do. Fortunately, being an Australian import, there is no rust anywhere on this car and the 'U' bolts came undone with no more than a quick wire brush and a dose of penetrating oil. I also knocked out the rear trunnion pins allowing the leaf springs to drop right down so that the axle could roll back freely.
