TriciaS
Posted: Sun Nov 27, 2016 9:32 pm Post subject: By-pass hose |
Hi,
I am new to this site and am having problems using the search as whatever I type in it just does not give me anything like what I am looking for so apologies if this subject is already covered somewhere.
We have a Hillman Super Minx 1966 1725cc and it is almost perfect but one niggle is the by-pass hose, it is looking very sorry for itself although not leaking I wouldn't like to trust it on a long journey so any idea where I can get one, preferably is there a concertina style one to fit as don't fancy taking the head off just for a little hose, now when we purchased it we were told the engine had had a complete rebuild but surely they would have replaced this hose , anyway we have previously done a bypass hose on a mini with the concertina type but not sure if the same one will fit .
Any info gratefully received |
Posted: Sun Nov 27, 2016 9:44 pm Post subject: |
Welcome to the forum Tricia
Give speedy spares a call, they will sort you out
http://www.speedyspares.co.uk/
Kevin |
TriciaS
Posted: Sun Nov 27, 2016 10:11 pm Post subject: |
Thanks for quick reply I have had a quick look at their website and can only see water pump bypass hose do you think this is the one as can't think off hand if it is attached to the water pump and too dark to go check Ha ha. |
Posted: Mon Nov 28, 2016 9:03 am Post subject: |
| TriciaS wrote: |
Their website is just an idea of what they stock and not very user friendly, ring them up, great people and will sort you out.
Kev |
Joined: 14 Oct 2016 Posts: 2146 Location: East Yorkshire
TriciaS
Posted: Mon Nov 28, 2016 10:44 am Post subject: |
| alastairq wrote: | http://www.rootes1725cc.info/wsm145/WSM145_A-Frames.htm
Is the above any use?
#7? Is that the part you need?
http://www.rootes1725cc.info/wsm145/cont145.htm
Goooogled Hillman Super Minx 1725cc diagram....the above was the first link..
Thank you so much for this, I actually have the older version in print but it only goes up to the MKIII and mine is the MKIV so a few differences, I did not think to check in the book so it was under my nose all the time Ha ha I was hoping someone would say the mini one will fit as they are so easy to get hold of but will buy from speedy spares instead. |
TriciaS
Posted: Mon Nov 28, 2016 5:33 pm Post subject: by-pass hose fitting |
| has anyone fitted one of these wth out taking head off , any ideas welcome |
Posted: Mon Nov 28, 2016 8:46 pm Post subject: Re: by-pass hose fitting |
| TriciaS wrote: | | has anyone fitted one of these wth out taking head off , any ideas welcome |
Just get the hose warm and it goes on fine, not sure why the head would need to come off?
Kevin |
TriciaS
Posted: Mon Nov 28, 2016 8:50 pm Post subject: Re: by-pass hose fitting |
| kevin2306 wrote: | | TriciaS wrote: | | has anyone fitted one of these without taking head off , any ideas welcome |
Kevin |
because to me it looks exactly like the mini ones and we had to take the head off of that first time as it sits under the head on top of the water pump , I will still look for the concertina style one as we used one on a mini and that made it much easier |
