Joined: 14 Oct 2016 Posts: 2145 Location: East Yorkshire
Posted: Tue Dec 06, 2016 4:01 pm Post subject: |
Whilst the V8 theme is in keeping with later Bristol tendencies, I'm sure I would prefer a straight 6?
I'm not sure how heavy the original Bristol 2 litre engine is/was, but the noted lightness of the Roverick V8 must be in its favour?
Would having a lighter engine up front have an effect on the designed dynamics for the whole car?
For a 6 cylinder engine, I would be looking at the BMW range.
Which has a link to the heritage of the original Bristol 2 litre sixes?
[I recall looking over a Bristol some years ago, whose original Bristol engine was being experimented with...in the form of a set-and-a-half of bike carbs being fitted to bespoke manifolds....it actually looked very impressive with the row of little ram pipes they came equipped with...not sure how pretty the whole thing looked once the proper foam filters were added, as they should have been?]
I know little of Bristols as a whole, being only an admiring enthusiast.
In fact, the only Bristols I have had any sort of close relationship with, usually had a second deck on top [but not always] and a seating capacity way beyond that expected of the cars. |
Posted: Tue Dec 06, 2016 4:06 pm Post subject: |
I suppose the V8 thinking is because by the 407 Bristol themselves had moved to V8.
But having seen a Triumph 2000/2500 (not sure which) in that red AC Greyhound which pops up at shows i think that is the way I would go,
I suspect power/weight ratio would be similar to the original _________________ Bristols should always come in pairs.
Joined: 31 Jul 2009 Posts: 1815 Location: Market Warsop, Nottinghamshire
Posted: Tue Dec 06, 2016 4:54 pm Post subject: |
I agree with the idea of a Triumph engine; the Bristol developed 80-100bhp depending on which version, the Triumph 2000 had 90bhp as standard (95bhp in the Vitesse) and can easily be tuned to 140bhp+ if you want a bit more. Looks right, sounds right, got to be the way to go! _________________ in the garage: a big empty space!
