johnmarshman Guest
Posted: Sun Sep 30, 2007 10:46 pm Post subject: Wot are these handles ? |
Help !
Need a key to lock the old herald special, but where did the manuf buy his handles ? Messrs Austin / Ford / ????
See pic of "open ended" handles at PAGE 4 of....
http://nickrichampion.mysite.orange.co.uk/
pip pip jm |
PAUL BEAUMONT Guest
Posted: Mon Oct 01, 2007 1:33 pm Post subject: |
| Wilmott Breeden (spelling probably wrong) in all probability, but they will come to pieces and you can probably reconfigure them to suit your key. If you need help give me a shout! |
alfanut Guest
Posted: Thu Oct 04, 2007 9:20 am Post subject: |
Hi John,
Am I right in thinking that the Wilmot Breeden (spelling probably even more wrong ) lock barrels are all basically the same and only the operating linkages are different for each car. If so, it should be easiest to find a working lock with key and swap the barrel over. If my memory hasn't gone completely, the earlier ones had the key number stamped on the face, but this disappeared when they worked out that anyone with a bunch of keys and a telescope could drive off with your pride and joy
Geoff |
johnmarshman Guest
Posted: Sat Oct 13, 2007 11:05 am Post subject: Wot are these handles ? |
thanks chaps !
I note that this name crops up on ebay in relation to locks, so gives me a useful clue when looking fo rold keys !
Also noted that barrel could be changed....
pip pip jm |
PAUL BEAUMONT Guest
Posted: Mon Oct 15, 2007 1:19 pm Post subject: |
| You probably don't need to change the barrels, They all come to pieces and then you just shuffle the internal parts to suit an existing Key. You only need an ounce of engineering knowhow (I dont have much more and I have fiddled with lots over the years). Still offering to help if you like. |
poodge
Posted: Mon Nov 26, 2007 5:54 am Post subject: handles? |
| They look like early Mini handles,or maybe A30/35? |
Posted: Tue Dec 18, 2007 6:49 pm Post subject: |
Hi John,
I think the A30/35 handles were smaller but I think Poodge is spot-on with the Mini suggestion
Regards,
Peter |
