pdn7
Posted: Wed Jan 11, 2017 8:43 pm Post subject: LUCAS 5SJ Screenjet Motor Housing Removal |
I want to service the electric motor on a Lucas 5SJ Screenjet but not sure how the motor is attached to the pump housing, there are no visible screws?
All advice appreciated.
Regards,
Paul
Rover P4 1957
Posted: Thu Jan 12, 2017 12:18 am Post subject: |
Unless the lower tube, containing the impeller, unscrews from the top plate/motor assembly (probably unlikely).
Then I would suggest that the black housing is a snap fit.
1)It could have protruding tangs underneath going into holes in the white part,
or
2)there could be tangs sticking up from the white part engaging in recesses inside the black part.
Try inserting a very thin knife blade between the 2, try all the way round.
If you find 2 spots (possibly opposite each other) where it wont pass along then try pressing either side at those points and lifting. That tries an answer to (1)
Similar principle to those Bleach bottle tops which have points you have to squeeze in order to turn them.
If that doesn't work try pressing the other 2 sides this could bulge out the side to suit the possibility (2) above.
Having typed all that, this suggests corner dowels.
http://www.scparts.co.uk/media/catalog/category//2/0/2087.gif _________________ Bristols should always come in pairs.
Joined: 14 Oct 2016 Posts: 2282 Location: East Yorkshire
Posted: Thu Jan 12, 2017 11:55 am Post subject: |
Slightly off-topic, but, looking at the diagram Penman posted above, the glass jar looks remarkably similar to a ''Bisto Best Gravy'' jar.
Indeed, I have done a comparison..... and the similarity is remarkable.
The price difference between a Bisto jar, and one from one of the posh equipment specialists,is also'remarkable'!
I would, however, be reluctant to make & fit one such item to my Dellow....for weight reasons. [Plus, the prospect of getting gravy in my eyes whilst driving isn't one to relish.] |
Penguin45
Posted: Thu Jan 12, 2017 3:35 pm Post subject: |
The lid on the washer bottle of my 'Crab is a Marmite one. Exact fit!
Posted: Thu Jan 12, 2017 3:42 pm Post subject: |
pdn7
Posted: Thu Jan 12, 2017 7:48 pm Post subject: |
Thank you Penman - perfect
Paul |
