how to search posts ???????
TriciaS
PostPosted: Mon Jan 30, 2017 5:42 pm    Post subject: how to search posts ??????? Reply with quote
I am having real problems and whatever I search for I always just get every post ever written with none covering the subject I need, how do I use th search and actually get to a post with similar problems and answers
PostPosted: Mon Jan 30, 2017 5:50 pm    Post subject: Reply with quote
Bottom left of the search page:
Quote:
Display results as: O Posts O Topics
Put a black dot in the Posts circle, Topics is the default.
TriciaS
PostPosted: Mon Jan 30, 2017 6:39 pm    Post subject: Reply with quote
I did that still no luck
Penguin45
PostPosted: Mon Jan 30, 2017 7:20 pm    Post subject: Reply with quote
If you type in "hillman dynamo", you get 840 results.
If you type in "hillman AND dynamo", you get 3 results, as the search facility is looking for those two words together, as opposed to every post with Hillman and every post with dynamo.
Hope that makes sense.
P45.
PostPosted: Mon Jan 30, 2017 8:51 pm    Post subject: Reply with quote
The renowned Boolean Search protocol; as well as AND you can also use OR and NOT as separators.
