new indicators and relay very erratic when engine is running
stevefizz
PostPosted: Mon Feb 27, 2017 11:40 pm    Post subject: new indicators and relay very erratic when engine is running Reply with quote
Restoring a 1938 vauxhall DX positive earth 12v
Installed indicators and a relay works fine with the ignition on but flash very erratic when the engine is running
do i need a solid sate voltage regulator
do i have a fault somewhere
have i wired it up wrongly
or something else
Thanks
steve
PostPosted: Mon Feb 27, 2017 11:59 pm    Post subject: Reply with quote
It points to the dynamo output being wildly variable - these being thermal are only slightly sensitive to engine speed and were fitted to dynamo cars - the standard factory fit works well on out Rover P4 and P5 and also on our 1938 P2 all of which have positive earth dynamos as standard factory fit. You are not using LED's are you?
Rover P2
Morris Mini Traveller Mk2
stevefizz
PostPosted: Tue Feb 28, 2017 1:14 am    Post subject: Reply with quote
Hi Phil
No just normal bulbs for now
this is the relay i got
http://www.ebay.co.uk/itm/12V-ELECTRONIC-INDICATOR-FLASHER-RELAY-POSITIVE-EARTH-GROUND-2-or-3-PIN-OPTIONS-/181922801187?hash=item2a5b71a623:g:U-4AAOSwbwlW~8cT
PostPosted: Tue Feb 28, 2017 1:56 pm    Post subject: Reply with quote
Is the earth good? I find that a poor earth is the cause of most bizarre electrical problems.
Good Luck!
PostPosted: Tue Feb 28, 2017 6:03 pm    Post subject: Reply with quote
It should work but I prefer the original electromechanical ones which need a narrow Wattage range. They lasted longer too
Rover P2
Penguin45
PostPosted: Tue Feb 28, 2017 6:09 pm    Post subject: Reply with quote
Just this very afternoon I bought one of the electronic flasher units (A 2 tag one from the same manufacturer) at my local Moss Europe, to replace the third tin can to have failed in the last three month. Half the price of the eBay one BTW.
P45.
stevefizz
PostPosted: Mon Mar 06, 2017 10:51 pm    Post subject: Reply with quote
The plot does thicken though. i had the dynamo cables the wrong way round. now occasionally the ignition warning light stays on when i turn the ignition off.
PostPosted: Mon Mar 06, 2017 11:20 pm    Post subject: Reply with quote
Cut out is sticking - what regulator is it? Lucas RF91?
Rover P2
stevefizz
PostPosted: Tue Mar 07, 2017 12:09 am    Post subject: Reply with quote
CJR3 i think, single bobbin, 3 bush dynamo
stevefizz
PostPosted: Tue Mar 14, 2017 7:55 pm    Post subject: Reply with quote
Okay i think i understand whats happening
measured the voltage with the engine running on tickover and got about 7volts
measured the voltage from the dynamo with dynamo disconnected and the f and d jumpered and got 3 volts
im going to created a new post for the dynamo
jp928
PostPosted: Tue Jun 20, 2017 7:35 am    Post subject: Reply with quote
I had crazy volts from my 3 brush 6v Lucas, no charging, despite genny being overhauled. Cleaned the cutout points with wet'n'dry, volts stabilized, charged 8A.
jp 26 Rover 9
