painting a plastic steering wheel
WOODY2
PostPosted: Mon Apr 03, 2017 8:56 am    Post subject: painting a plastic steering wheel Reply with quote
Hi, I've now made 2 attempts at painting the plastic steering wheel and the control knobs on my 51 Simca 8 and it's a cock-up again!The paint does'nt dry in some places and the steering wheel paint crackled and came off.The plastic on the wheel is itself quite crackled so maybe I should stabilise this with something first? What would be the best primer to use?
Cheers,Tony.
PostPosted: Mon Apr 03, 2017 9:10 am    Post subject: Reply with quote
There is company http://www.steeringwheelrestoration.com/home in the UK. I've not used their services but it might be worth getting a quote.
bob2
PostPosted: Mon Apr 03, 2017 10:50 am    Post subject: Reply with quote
There is a primer used for plastic bumpers, wheel trims and the like on modern cars. It would probably do the trick in your case. It is available in aerosol form too from automotive paint suppliers.
PostPosted: Mon Apr 03, 2017 11:38 am    Post subject: Reply with quote
I've used plastic primer, or adhesion promoter as I think it's also called, on some interior bits on my project where the black has faded too far. I don't know how well it would go on something like a steering wheel that is being used all the time - a mate painted the gearknob on his modern car because the factory finish was getting worn, and it's lasted reasonably well but needs doing again now.
bob2
PostPosted: Tue Apr 04, 2017 9:00 am    Post subject: Reply with quote
Well I have painted the steering wheel on my hillman with satin black aerosols and not used the plastic primer but normal primer filler and its still going strong now some 5/6 years later.
WOODY2
PostPosted: Tue Apr 04, 2017 7:42 pm    Post subject: Reply with quote
Thanks for that,I will get a quote from the wheel restoration company.
ajlelectronics
PostPosted: Sat Apr 08, 2017 9:12 pm    Post subject: Reply with quote
Epoxy primer after good cleaning and abrading.
Evans Waterless Coolants
Sat TV / Aerial systems etc: http://www.ajlelectronics.co.uk
WOODY2
PostPosted: Sun Apr 09, 2017 9:46 pm    Post subject: Reply with quote
I've never used epoxy primer, is this a special one for plastic? I will look into this as I would like to do the job myself.Thanks.
ajlelectronics
PostPosted: Mon Apr 10, 2017 7:54 pm    Post subject: Reply with quote
Epoxy primer is the go to product for many surfaces. Plastics, aluminium and fibreglass are ideal substrates. It is waterproof, tough and non isocyanate. It is the only primer that can be used on a panel which is then left outside for twelve months!
Lechler 29107 is the one I use. Jotun is better for undersides and less visible surfaces.
