Brake cylinder rebuilding
billysugga
PostPosted: Sat Apr 22, 2017 3:27 pm    Post subject: Brake cylinder rebuilding Reply with quote
Hi folks 2 questions
1 is it ok to use the red grease when rebuilding brake servos the piston type?
2 what kind of oil should I use in the vacuum piston housing( I have heard mention of mineral oil?) ?
The particular servo is a bendix hydrovac3
Thanks
Volvo Sugga ,Volvo Trygge
I just wish one was working!
Kenham
PostPosted: Sat Apr 22, 2017 5:10 pm    Post subject: Reply with quote
In my book it says use castor oil for the leather washer in the servo.
billysugga
PostPosted: Sat Apr 22, 2017 5:51 pm    Post subject: Reply with quote
Thanks kenham
Then if I have any spare I can drink the stuff( not sure what it does to the body though)
Kenham
PostPosted: Sat Apr 22, 2017 7:06 pm    Post subject: Reply with quote
Not too sure , please let us know Very Happy
petelang
PostPosted: Sat Apr 22, 2017 7:43 pm    Post subject: Reply with quote
I'm deeply interested how you get on Billy as I need to overhaul mine. Have you found instruction manual on its set up and any source of spares?
Mine seems to have a large amount of play in all the pivot linkages (but the piston bit works fine). Are the lever eyes bushed?
billysugga
PostPosted: Sat Apr 22, 2017 9:20 pm    Post subject: Reply with quote
Hi Pete Ian wonnacot at classic spares got me the main hydraulic seals the rest looked good but it could be a while before I can let you know the results.
