Cannot turn distributor ford pop 103e
Paul fairall
PostPosted: Sun May 07, 2017 9:20 pm    Post subject: Cannot turn distributor ford pop 103e Reply with quote
Fitted electronic ignition to my 10hp sidevalve and found the distributor cannot be turned to set the ignition timing. Clamp turns but dizzy is solid. Sprayed with liquid spanner but no go. Will continue to soak it the next few days. Looks like I may need to remove the carb to get at it. Anyone had this problem and can advise.
1957 ford popular
PostPosted: Sun May 07, 2017 10:13 pm    Post subject: Reply with quote
Paul,
You don't have access to a big Stinson type pipe wrench do you? You could grab the distributor body down low with that and lever it around.
Art
Paul fairall
PostPosted: Sun May 07, 2017 10:49 pm    Post subject: Reply with quote
Yes Art I do have 24" stilsons, is the dizzy strong enough to do that?
1957 ford popular
PostPosted: Mon May 08, 2017 7:45 am    Post subject: Reply with quote
The little adjustment screw that screws into the head, where the adjustment scale is, has also freed off ok?
PostPosted: Mon May 08, 2017 11:12 am    Post subject: Reply with quote
Maybe try a bit of heat on the head. Ideally oxy-acetylene but propane might work.
PostPosted: Mon May 08, 2017 11:48 am    Post subject: Reply with quote
Paul,
From memory the case is cast iron and down at the bottom where the sides end should be strong enough. I don't think it would take much to move and if it does DESIST.
Art
Paul fairall
PostPosted: Mon May 08, 2017 4:18 pm    Post subject: Reply with quote
yes screw loose and clamp and the clamp turns freely but not the dizzy.
1957 ford popular
Paul fairall
PostPosted: Mon May 08, 2017 4:22 pm    Post subject: Reply with quote
As I said will spray it with release oil a few times and try to move it. If not will leave well alone until I have the engine out and head off. Don't fancy oxy-acetylene on it while it's in the car and fixed to the block.
1957 ford popular
PostPosted: Mon May 08, 2017 5:49 pm    Post subject: Reply with quote
Hi.the head is simple to remove without removing the engine. [just buy a new gasket]....it's only a lid, after all.... Smile
Paul fairall
PostPosted: Mon May 08, 2017 6:02 pm    Post subject: Reply with quote
I've got enough to do with body repairs and want to keep it in running order for the summer. It's running fine as is.
1957 ford popular
