Kleftiwallah
Posted: Tue May 30, 2017 8:29 pm Post subject: Positioning of carburettors. |
Soon...I shall be attempting to mount two Solex 26FV carbs onto a Hotchkiss aircooled V twin. Am I correct in thinking that if the float chamber is below the level of the fuel tank I will not need a fuel pump? ? ?
More questions to follow...
Over to you knowledgeable peeps. Cheers, Tony.  |
billysugga
Posted: Tue May 30, 2017 10:19 pm Post subject: |
Is the tank outlet on the bottom or top of the tank?
Because you may have to create a syphon.
If the outlet is on the bottom then no you shouldn't need a pump.
What is the engine out of? Any pics? _________________ Volvo Sugga ,Volvo Trygge
I just wish one was working! |
Posted: Wed May 31, 2017 9:02 am Post subject: |
| In principle the answer is yes! Fit a shut off tap to the tank though! |
Kleftiwallah
Posted: Wed May 31, 2017 12:51 pm Post subject: |
The fuel rmerges from the bottom of the tank, there is already a valve fitted to the tank.
Thanks for those helpful anwers. Cheers, Tony.
'Tis in (or soon will be) a BSAFWD TW31. |
