Fuel tank on 1955 A30
Guernseyman
PostPosted: Sun May 21, 2017 6:18 pm    Post subject: Fuel tank on 1955 A30 Reply with quote
Some time ago I purchased a Jan 1955 4-door A30 with 19K miles on the clock. I ran her for 12 months but then she went into storage for two years. Now I have decided to get her back on the road but she won't start. The petrol coming out of the electric pump was a horrible yellow colour so I decided to drain the tank and clean the fuel lines. The fuel line was clear but I then made what I think was a serious mistake. I refitted the fuel line but and gave the it another blast of air but it didn't go anywhere. I removed the fuel line again and it was clear but the union on the tank appeared to be blocked.
Can someone tell me if there is a non-return valve in the tank and what are my chances of freeing it up as there is obviously no access from inside the tank. I suspect that the valve was fitted to the bottom half of the tank before the top half was fastened to it in which case I have a serious problem.
DM
PostPosted: Sun May 21, 2017 6:57 pm    Post subject: Reply with quote
No non return valve in the tank.
Your tank idealy needs to come out and be cleaned out inside.
PostPosted: Mon May 22, 2017 12:25 am    Post subject: Reply with quote
Hi "Guernsey Man".... Maybe the OCC's first Channel Island's member ?
My parents and way back were from Jersey.
Welcome.
Guernseyman
PostPosted: Mon May 22, 2017 9:09 am    Post subject: Fuel tank A30 Reply with quote
Good morning
Thank you for your advice DM. The tank is out of the car and I will see if cleaning it out clears the problem. I will report back.
Hi Peter. A lot of Channel Islanders left for Canada years ago. Good to know you.
Guernseyman
PostPosted: Wed Jun 07, 2017 11:41 pm    Post subject: A30 fuel tank Reply with quote
Cleaned the tank and loads of gunge came out. Fuel outlet now clear, fuel line reconnected and fuel added. She started up almost immediately and is now running like a sewing machine.
Many thanks for your sound advice DM.
PostPosted: Thu Jun 08, 2017 8:17 am    Post subject: Re: A30 fuel tank Reply with quote
Thanks for the update, it'd be interesting to see a thread all about the A30 in the Austin section sometime Wink
