Solex 26FV carb'
Kleftiwallah
PostPosted: Sun Jun 11, 2017 6:14 pm    Post subject: Solex 26FV carb' Reply with quote
Anyone got any clues / hints /suggestions about the basic setting up of this carburettor when starting up for the first time?
Cheers, Tony. Confused
PostPosted: Sun Jun 11, 2017 6:43 pm    Post subject: Reply with quote
Hi Tony,
It's a fairly simple carburetor. The only adjustments are the slow running mixture screw and idle speed. It won't be critical if these are not correctly adjusted for first starting. You could screw it fully in the mixture screw then unscrew perhaps 1.5 turns but to honest you can't really adjust it until the engine has reached normal working temperature.
Set the idle speed adjustment just to very slightly open the butterfly.
Kleftiwallah
PostPosted: Tue Jun 13, 2017 9:07 pm    Post subject: Reply with quote
Thanks Peter for that informative & heartening reply.
Cheers, Tony. Razz
