1927 Morris Cowley Flatnose
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 11, 12, 13  Next
Miken
PostPosted: Mon Jun 12, 2017 12:18 pm    Post subject: Re: 1927 Cowley Reply with quote
bjacko wrote:
Yes the sheets have an illustration for each tool. If you are a Morris Register member they are available on their website.
OK thanks
Miken
PostPosted: Wed Jun 14, 2017 10:05 pm    Post subject: Reply with quote
I had a problem with one of my headlamps not working.
On investigation I discovered that the 90 year old bakelite bayonet fitting had disintegrated.
This is how I have repaired it:
Here is the old broken part;
I bought a universal 2 pin bayonet fitting. Sawed off the remains of the old fitting and made up a little brass socket on my lathe to accept the new fitting;
It fits together like this;
I made a tool to expand the bush into the reflector;
Here it is expanded securely into the reflector;
I have assembled the new socket into the brass bush using loctite bearing retainer rather than a permanent retainer in case i ever want to dismantle it.
The other lamp looks a bit ropey so I will do that one the same.
PostPosted: Thu Jun 15, 2017 12:19 am    Post subject: Reply with quote
Fantastic work. Love the way you handled this instead of going the way which most "restorers" think is the norm: replace by new.
PostPosted: Thu Jun 15, 2017 8:19 am    Post subject: Reply with quote
I am amazed by the effort you put into sorting out all these problems so precisely. It makes me wonder how I manage to restore cars without a lathe or the skill to use one. Top work!
Miken
PostPosted: Thu Jun 15, 2017 9:27 am    Post subject: Reply with quote
Thanks for the kind comments.
My projects are usually driven by having more enthusiasm than cash.
A lathe, even a small model makers version can be invaluable for all sorts of renovation work.
I think everyone should own one!
There are so many times when you find you need a spacer, bush, stud or non standard bolt.
PostPosted: Thu Jun 15, 2017 3:39 pm    Post subject: Reply with quote
Mike,
Nice work. The only comment I would make would be to split the bushing and have a clamp. The usual method to focus these lamps is sliding the bulb holder in or out.
Art
Miken
PostPosted: Fri Jun 16, 2017 6:21 am    Post subject: Reply with quote
Yes that would have worked. I haven't seen them like that so didn't think of it.
Miken
PostPosted: Fri Jun 16, 2017 10:08 pm    Post subject: Reply with quote
Mr Morris thoughtfully provided a tapped hole in the top of the Cowley cylinder head to enable a length of rod to be inserted to determine TDC.
This is filled with a 8 x 1mm threaded plug.
Turning the engine over using the starting handle I found it a bit tricky to accurately locate TDC so i made this up to assist. It allows you to see exactly when to stop winding.
Miken
PostPosted: Wed Jun 21, 2017 10:04 pm    Post subject: Reply with quote
Back on the road at last!
Going down to Sainsburys to fill up.
My mate Phil in the dickey seat filming.
It looks a lot faster than it actually was.
It needs a lot of running in.
Hope the video plays
https://www.dropbox.com/s/pz8ivp849ucry0x/WP_20170618_11_20_04_Pro.mp4?dl=0
PostPosted: Wed Jun 21, 2017 10:30 pm    Post subject: Reply with quote
Excellent. Very Happy
Penguin45
PostPosted: Wed Jun 21, 2017 11:47 pm    Post subject: Reply with quote
Very well done indeed.
P45.
PostPosted: Thu Jun 22, 2017 8:34 am    Post subject: Reply with quote
superb news, enjoyed the video too, many thanks for that
kev
PostPosted: Thu Jun 22, 2017 11:42 am    Post subject: Reply with quote
Well done. Nice you had the weather for that run too.
PostPosted: Thu Jun 22, 2017 2:30 pm    Post subject: Reply with quote
As always, interesting to read your updates and get a glimpse of what OCC forum-ers are tinkering with.
Miken
PostPosted: Thu Jun 22, 2017 8:29 pm    Post subject: Reply with quote
Thanks all.
Been out and about today.
A couple of times I have thought about giving it a polish.
But settled for cleaning the greasy hand prints off the windscreen.
Just noticed that in the video you can see the crappy chrome plate on the r/h budgie mirror literally peeling off in the fearsome 25mph breeze.
Page 8 of 13
