Threadform has me fummoxed!
Kleftiwallah
PostPosted: Tue Jul 25, 2017 4:15 pm    Post subject: Threadform has me fummoxed! Reply with quote
The securing threaded shafts of a British Jaeger speedometer have me flummoxed. 34 T.P.I. and 3/16" diam', my 'very near' reads 0.190" or 4.84mm.
I've been through Mr F.J. Camm's Newnes Screw Thread Tables and I'm beat.
Anyone any ideas what this thread is? ? ?
Over to you Chaps and Chapesses. Sad
Cheers, Tony.
V8 Nutter
PostPosted: Tue Jul 25, 2017 7:07 pm    Post subject: Reply with quote
Are you sure it's 34 T.P.I.? A number 10 A.N.F has the same diameter but 32 T.P.I. Having said that I seem to remember reading somewhere some American threads were changed in the 1930's
PostPosted: Tue Jul 25, 2017 10:19 pm    Post subject: Reply with quote
I would agree with V8 that it is more likely to be 32 tpi x 3/16" which also happens to be 2BA which is the same as 10/32 unf. The only difference is in the size of the nuts. 2BA will have smaller 5/16" SAE or 2BA spanner size and 10/32 will be 3/8 SAE spanner size. IMHO British Jaeger is more likely to be 2BA.
Art
Paul fairall
PostPosted: Tue Jul 25, 2017 10:32 pm    Post subject: Reply with quote
Art
10/32" ? 5/16"
1957 ford popular
Kleftiwallah
PostPosted: Wed Jul 26, 2017 11:37 am    Post subject: Reply with quote
Thanks for all those interesting and educational replies.
I got by with an M5 X .8.
Cheers all. Tony.
V8 Nutter
PostPosted: Wed Jul 26, 2017 2:07 pm    Post subject: Reply with quote
I never thought to look at British threads, I just assumed a publication by F.J. Camm would have covered everything. I must have tapped hundreds of holes 2BA when I was an apprentice, come to think of it, I broke more than a few taps.
PostPosted: Wed Jul 26, 2017 8:11 pm    Post subject: Reply with quote
Jaeger / Smiths instruments used BA threads.
PostPosted: Wed Jul 26, 2017 10:59 pm    Post subject: Reply with quote
Paul,
The Yanks use wire gauge to express diameters under 1/4". So 10/32 would be a 10 gauge (3/16") with 32 TPI. The 5/16 is the SAE size of spanner/socket the also fits 2BA.
Art
jp928
PostPosted: Fri Jul 28, 2017 8:11 am    Post subject: Reply with quote
As long as the the threads are short and a bit soft M5 is close enough to 10-32 - a 0.8mm pitch gives 31.75 tpi. I use M5s in American 10-32 model aero fittings when I am pressed.
jp 26 Rover 9
Paul fairall
PostPosted: Fri Jul 28, 2017 6:30 pm    Post subject: Reply with quote
47Jag wrote:
Paul,
Art
so 10/32 is not a fraction of an inch then.
1957 ford popular
PostPosted: Fri Jul 28, 2017 8:28 pm    Post subject: Reply with quote
Paul,
NO. Perhaps I didn't express it correctly. Maybe it should read 10-32.
Art
Paul fairall
PostPosted: Fri Jul 28, 2017 9:41 pm    Post subject: Reply with quote
47Jag wrote:
Paul,
Art
so 10 is the wire gauge and 32 is tpi. Jeez, what's wrong with measuring something by its diameter. Even cable is measured millimeters squared not wire gauge. That was fine when people were used to looking at something and recognizing its wire gauge size.
1957 ford popular
PostPosted: Sat Jul 29, 2017 10:21 am    Post subject: Reply with quote
Paul fairall wrote:
47Jag wrote:
Paul,
Art
And then of course there's the problem of which wire gauge! IIRC there's an American wire gauge as well as a Birmingham wire gauge and the Standard wire gauge. There may be others, who knows..? Rolling Eyes
Paul fairall
PostPosted: Sat Jul 29, 2017 5:27 pm    Post subject: Reply with quote
I will stick with my micrometers
1957 ford popular
