Kleftiwallah
Posted: Sat Jul 29, 2017 2:18 pm Post subject: LED instrument lighting. |
Can anyone help me with a circuit diagram and checklist for LED lighting for the instrument panel, suppliers of lamps, holders and rheostats would help? I would like to illuminate the instruments from within a 'tin box' I've constructed.
Many thanks in anticipation. Cheers, Tony.  _________________ It may work in practice, but not necessarily in theory! |
Posted: Sat Jul 29, 2017 10:34 pm Post subject: |
My instruments were originally lit by four 5 watt BA15 side lamp bulbs. I replaced them with plug-in replacement LEDs. The filters on the instruments were blue translucent plastic and these work well with the high blue content of the LEDs.
jp928
Posted: Sun Jul 30, 2017 9:32 am Post subject: |
The important part of LED bulbs is they are polarity sensitive - they have +ve and -ve sides, so you need to get that right or they wont light up. You may also need to test to find out what wattage you need to be effective - my first try was too dull. Also, wedge type 'bulbs' (wedge shaped at the back, and push into sockets) sometimes come with both the wire leads folded back and around the rear edge , so both wires (+ve and -ve) are on BOTH sides - if you fit these into some socket types you have a lovely short circuit! 80s Porsche dash panels do this, so watch out.
jp 26 Rover 9 |
Riley Blue
Posted: Sun Jul 30, 2017 10:57 am Post subject: |
Peter - that's exactly what I want to do with my Riley's dash lights so it's good to see the result of switching to LEDs.
JP - I always thought they were polarity sensitive too, then I read this page which mentions 'bi-polarity':
http://www.dynamoregulatorconversions.com/dash-board-panel-lamp-bulbs-shop.php _________________ David
1963 Riley 1.5
1965 Riley 1.5 |
Posted: Sun Jul 30, 2017 11:07 am Post subject: |
I confess that I had converted to negative earth to accommodate a tracker so LED polarity was less of an issue for me.
Kleftiwallah
Posted: Sun Jul 30, 2017 11:38 am Post subject: |
Thanks for all those helpful replies...now where is that circuit diagram?
riley541, do these people sell adjustable resistance/dimmers/ rheostats as well?
Cheers, Tony  _________________ It may work in practice, but not necessarily in theory! |
Posted: Sun Jul 30, 2017 12:55 pm Post subject: |
| Kleftiwallah wrote: | Thanks for all those helpful replies...now where is that circuit diagram?
Cheers, Tony  |
Hi Tony,
It looks like your car already has negative earth and I think your dash lamp is just the same BA15 type used in the side lamps. You just need to source a 6 volt LED version and plug it straight in.
See: http://tinyurl.com/yd2pxkt6
Joined: 25 May 2011 Posts: 2727 Location: South Cheshire
Posted: Mon Jul 31, 2017 10:55 am Post subject: |
| Kleftiwallah wrote: | | riley541, do these people sell adjustable resistance/dimmers/ rheostatts as well? |
When you're buying LEDs, make sure they can be dimmed, some will not light until they reach a certain voltage so cannot be adjusted - they're either on or off. |
Kleftiwallah
Posted: Mon Jul 31, 2017 8:09 pm Post subject: |
Good evening Peter, the trike is Neg' earth and converted to 12V but the starter motor is still 6V.
Thanks again all for info' sent. Cheers, Tony. _________________ It may work in practice, but not necessarily in theory! |
