dazdawn07 Guest
Posted: Wed Oct 31, 2007 1:54 pm Post subject: mgb gt jubilee |
Hi all well we started the strip down now, plan is to have on raod for next summer, a few qusetions,what does the overdrive do on a mg. also where do i get the engine number on my plate on engine it says bhm111 etc but on a jubilee web site they put 18v etc etc... not sure what it means
below a few pics
daz.dawn
pigtin Guest
Posted: Wed Oct 31, 2007 4:37 pm Post subject: |
Can't help with the numbers but it looks like a great project... Compared to my Sprite, it only needs a wipe with an oily rag.
Don. |
UKdave2002 Guest
Posted: Wed Oct 31, 2007 5:53 pm Post subject: |
Hi Dazdawn
I may be breaking an MGB GT, if you need any bits, its complete, includes some new carbs (done 1500 miles) and and a little used stainless steel exhaust.
dazdawn07 Guest
Posted: Tue Nov 06, 2007 9:09 pm Post subject: |
thanks for that mate
so far we need is a oil cooler, nothing else as still on the strip down wont be re buiding till after new year
thanks
daz dawn |
dazdawn2007
Posted: Mon Dec 10, 2007 8:14 pm Post subject: |
| how do you get to the bolts to undo the doors ??? do you need to take the wing off as cant get to the bolt??? thanks |
Posted: Mon Dec 10, 2007 8:59 pm Post subject: |
I have no idea, but can you not get up inside the wing?
Joined: 23 Nov 2007 Posts: 4267 Location: South Cheshire
Posted: Tue Dec 11, 2007 9:11 am Post subject: |
Unless my memory is playing tricks , there are 4 bolts per hinge which you get at from the door side of the A pillar. Or you can remove the door from the hinge, I think there are 2 bolts per hinge, you will need to remove the trim etc if you do it this way.
dazdawn2007
Posted: Mon Jan 21, 2008 11:34 pm Post subject: |
Here are a couple of the latest pictures. Any advice on what to paint underneath the car to cure the rust and preserve?
Posted: Tue Jan 22, 2008 3:50 pm Post subject: |
Hi , think have allready posted this ; below is where you need to waxoil;
Brian M
Posted: Tue Jan 29, 2008 8:44 am Post subject: |
Are similar diagrams available for other cars? _________________ Brian
Rich5ltr
Joined: 28 Mar 2008 Posts: 681 Location: Hampshire, UK
Posted: Mon Mar 31, 2008 6:17 pm Post subject: Re: mgb gt jubilee |
| dazdawn07 wrote: | Hi all well we started the strip down now, plan is to have on raod for next summer, a few qusetions,what does the overdrive do on a mg. also where do i get the engine number on my plate on engine it says bhm111 etc but on a jubilee web site they put 18v etc etc... not sure what it means... daz.dawn
| Hi Daz Dawn, by now I guess you are getting on with your project, any update? By the way, what did you mean when you said "what does the overdrive do on an MG?" - The overdrive is pretty straight forward, but what's your question? Rgds Rich... |
