old gto Guest
Posted: Mon Nov 12, 2007 12:23 am Post subject: Another "What is it?" |
Here`s an item for you guys....anybody ever seen one of these?
Any guesses as to what it is? Here`s a hint.....
I know what it is, but am too young (age 50-something)
to have used one.
47p2 Guest
Posted: Mon Nov 12, 2007 12:31 am Post subject: |
| Would it be a garage heater? |
buzzy bee Guest
Posted: Mon Nov 12, 2007 1:40 am Post subject: |
Is it an early automobile heater, for inside the cabin, or like sugested a garage/sump heater?
P.S...If I am wrong have you any beter pictures of the writing on it, or does that give the game away?  |
47p2 Guest
Posted: Mon Nov 12, 2007 9:10 am Post subject: |
| Looks too high to be a sump heater which were only about 5 or 6 inches high, this looks much taller |
47p2 Guest
Posted: Mon Nov 12, 2007 9:17 am Post subject: |
Unless it waas a sump heater for trucks  |
pigtin Guest
Posted: Mon Nov 12, 2007 10:59 am Post subject: |
I don't know how tall it is? but I bought something similar in the 50s to hang in the engine compartment of my Standard Big 9. It is easy to forget how much room there was under the bonnet of the old sidevalves, and there was usually room alongside the engine for something like that.
On a similar subject: anyone ever heard of a mains powered (240v) heater that fitted in the top hose? I have something in my shed that almost certainly was used for that purpose. |
buzzy bee Guest
Posted: Mon Nov 12, 2007 11:10 am Post subject: |
I am wary about a sump heater as it has a wire to hang it from, surely a sump heater wouldn't have this?
buzzy bee Guest
Posted: Mon Nov 12, 2007 11:12 am Post subject: |
I think pigtin has posted at the same time as me, and I seem to agree with him.
47p2 Guest
Posted: Mon Nov 12, 2007 12:23 pm Post subject: |
Yes Rick, they are still available here on Amazon for less than £20.00.
Keeps your engine nice and cosy in the winter  |
Penman Guest
Posted: Mon Nov 12, 2007 12:32 pm Post subject: |
I remember having both an under bonnet heater like this (well different pattern but same job) and also an undersump one.
If you didn't have off road parking and had to leave the car on the road this type was less likely to get nicked, but you had to remember to remove it before starting up whereas with the sump heater you could just start up and drive away leaving it to keep your garage warm (Not so cold) for the next few hours.
In some countries I believe they have a sort of immersion heater set into the cooling system which is plugged in to the domestic power supply overnight. |
47p2 Guest
Posted: Mon Nov 12, 2007 12:46 pm Post subject: |
| Penman wrote: | Hi
Centrally heated cars, now that sounds a great idea when living in Scotland
Kenlowe pre-heater
Central heating for your car |
old gto Guest
Posted: Tue Nov 13, 2007 1:11 am Post subject: |
I believe pigtin has it. It is an "Auto Motor Heater", a small kerosene heater designed to hang inside the engine compartment on very cold nights, to prevent the engine block from freezing.
The small hook on the top fits right over the radiator support rods (from the radiator to the cowl). Light the fire, hang it in, and close the hood, and it should keep the engine compartment warm through the snowiest of nights!
Used primarily, I think, in the 1930s.
(Please pardon the V-8 in this example, LOL!)
