Hidem caps.
Penguin45
PostPosted: Thu Mar 08, 2018 1:26 am    Post subject: Hidem caps. Reply with quote
We have a club member having some interior upholstery work done on a Wolseley 12/32 convertible. He needs "Hidem caps"
Hidem cap by Penguin 45, on Flickr
These. Anyone know of a source for such a thing?
Thanks,
P45.
PostPosted: Thu Mar 08, 2018 9:37 am    Post subject: Reply with quote
Maybe they can be found here although the search for "hidem" came up empty. They do have lots of interior finishing stuff though.
https://www.restorationstuff.com/ecommerce/
L5Foye
PostPosted: Mon May 28, 2018 7:46 pm    Post subject: Reply with quote
There are such things as hidem end caps. Is it these your friend is looking?
Vulgalour
PostPosted: Wed May 30, 2018 3:14 am    Post subject: Reply with quote
If you get really stuck on this, there's a square Model T type end cap that should have enough material to be modified. You'd need two caps to make one corner cap, basically trim off the return on one side and then cut the other side at 45 degrees, weld together and dress back before applying whatever finish you wanted (presumably painted). It's a fair amount of work for such a small item.
https://www.modeltford.com/item/welt-tb.aspx
Unlike the pointed ones that seem easier to get, these have a useful square profile. There's a lot of suppliers of them too, so price and quality does vary.
petelang
PostPosted: Wed May 30, 2018 2:49 pm    Post subject: Reply with quote
Is this what your looking for?
Woolies trim catalogue.
[img]https://drive.google.com/file/d/12lZgcjuRRkAobYEGAwAUfcpPT9YVSbeE/view?usp=drivesdk[/img]
https://www.woolies-trim.co.uk/category/344/hidem-banding
Penguin45
PostPosted: Wed May 30, 2018 6:06 pm    Post subject: Reply with quote
Thanks all. I'll pass the info on to uor Club member.
P45.
