Smiths gauges
trampintransit
PostPosted: Sun Jul 22, 2018 2:37 pm    Post subject: Smiths gauges Reply with quote
The speedo on the Armstrong has suddenly gone bonkers. Sounds like the magnet is touching the needle backplate or whatever it's called...I'm ahppy to take it out and have a look, but even if I get it apart I'll presumably reveal a broken or worn part...so what's next...where does one go for parts for these things?
For the record, it says '1080' on the front..which also seems to be the number on a Jag420 speedo which has a different max speed, so I'm not sure useful the code is?
There must be a Smiths guru out there somewhere?
'60 Armstrong Siddeley Star Sapphire
'80 Reliant Scimitar
'47 Jaguar MKIV --- in bits!!!!
trampintransit
PostPosted: Sun Jul 22, 2018 2:42 pm    Post subject: Reply with quote
Ah ,,found these...
http://obswww.unige.ch/~wildif/cars/docs/Smith-jaeger_speedo_repair.pdf
and
http://www.jdo1.com/speedos.html
But that doesn't look like a source of parts..I'd like to try to fix it myself?
PostPosted: Sun Jul 22, 2018 3:39 pm    Post subject: Reply with quote
You could also try:
http://www.speedograph-richfield.com/
PostPosted: Sun Jul 22, 2018 8:54 pm    Post subject: Reply with quote
TT,
By bonkers do you mean that the needle is oscillating wildly? This can be caused by the speedo cable needing cleaned and re-lubricated. Disconnect from the speedo and pull the cable into the car. Try that first before opening the speedo up.
Art
jp928
PostPosted: Mon Jul 23, 2018 7:54 am    Post subject: Reply with quote
Sounds like cable windup - part gets stuck briefly the releases sharply then sticks again. The number on the face is commonly revs/mile, for calibration purposes.
jp 26 Rover 9
