Replacement for Fograngers on Jaguar Mark 2
Ellis
PostPosted: Wed Aug 29, 2018 4:14 pm    Post subject: Replacement for Fograngers on Jaguar Mark 2 Reply with quote
Ladies and gentlemen may I have your opinions and advice please.
Below is a photo of the Fogranger lights on the front of a Jaguar Mark 2 :
A traditional look and contemporary to the Mark 2. In terms of practicality of additional illumination they are useless even the alternative Spotrangers .
I know that Jaguar's designer Ian Callum caused a lot of controversy with his interpretation of an updated Mark 2 but have a look at his idea for what he has designed in their place .
I'm not into plagiarism but I do like his idea and would like to recreate the additional lights on my own Mark 2 in a similar way and be useful as well
The Fogranger or Spotranger are simply bolted on from behind through a hole in the recess.
Have any of you any ideas how he's created this idea? I thought he may have used 7" Tractor lights but someone has suggested he's used 5 3/4" driving lights from some other manufacturer.
Can you all have a think and let me know your ideas?
Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet
PostPosted: Wed Aug 29, 2018 7:44 pm    Post subject: Reply with quote
Ellis,
The problem I see is the lack of space in the Ranger casing. As you know the lamp sits vertically with the contacts cuilt into the rear of the shell. Ive seen a sealed beam unit with the terminals bent flat that fitted the rim (I think it was a Lucas product) but I can’t remember the model name. It looks like this:-
https://www.carandclassic.co.uk/uploads/new/4596291.jpg
Edit, What about the WFT576 that they used to fit as reversing lamps to the rally Minis https://www.ebay.co.uk/itm/Lucas-WFT576-Centre-Mounting-Foglight-Fog-Light-for-Sprite-Mini-Cooper-S/192581924136?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D53672%26meid%3D9b3fc776c4494400a4b1f8da1f2f1bd1%26pid%3D100005%26rk%3D4%26rkt%3D7%26sd%3D142898236195%26itm%3D192581924136&_trksid=p2047675.c100005.m1851
Art
Ellis
PostPosted: Wed Aug 29, 2018 9:19 pm    Post subject: Reply with quote
Art, thank you very much for your reply and for taking the time and trouble to investigate and find those links. I like the second idea.
I've got plenty of time to think about this but what you given me is food for thought.
Ellis
PostPosted: Thu Aug 30, 2018 12:49 am    Post subject: Reply with quote
Ellis
The WFT576 will be an improvement, but not by a lot & it's a very wide fog beam. There is a spot version WLR576.
I think I'd take a look at 5 3/4" headlight units in the existing shells. See if you can find any old unit from any 4-headlamp car & see what mods might be needed to the shell - it might not be much.
Then look for Cibie 57-30-02, 57-32-02 or -07 for just the glass unit.
2002 MINI Cooper 'S'
Ellis
PostPosted: Thu Aug 30, 2018 11:52 am    Post subject: Reply with quote
Ellis
Thank you MVPeters. The more suggestions the better. The smaller size headlights from a Jaguar 420 have also crossed my mind.
At this rate I'm sure we are all going to agree on a mutually satisfactory solution. Smile
PostPosted: Thu Aug 30, 2018 3:22 pm    Post subject: Reply with quote
Surely, a fog light should have a wide, but flat, beam? So the water droplets don't lift the light beam too much?
Personally I'd have a couple of spots in there, maybe linked to full beam?
Ellis
PostPosted: Sat Sep 08, 2018 5:59 pm    Post subject: Reply with quote
Thank you all for your suggestions and advice and what I have decided to do is to uprate the headlamps and fit 2 x Lucas WLR 576 spotlights in place of the fograngers.
To try to fit a pair of 5 3/4" headlamps would have meant some bodywork alterations which although aesthetically attractive on the Ian Callum Mark 2, I still want my Mark 2 to have the original look.
Thank you all.
For those who may be interested the Lucas WLR 576 Spot lamp look like this :
https://www.ebay.co.uk/itm/Lucas-WLR576-Centre-Mounting-Spotlight-Spot-Light-Lamp-for-Sprite-Mini-Cooper-S/202352231735?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
And the uprated headlamps are going to be these ;
https://www.ebay.co.uk/itm/Classic-Austin-Mini-P700-7-Halogen-Headlight-Head-Lamp-Tripod-Conversion-Kit/261756715956?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
It's going to be a kitty emptying time methinks. Still the 15 year old son of a friend of mine has been given a new bike on his birthday.
"£500?" I asked.
With a sad shake of the head his father answered "No change from £3000 and the warranty does not even cover the bearings..........."
