Austin Seven Ruby ARQ rejuvenation
Goto page Previous  1, 2, 3 ... 10, 11, 12, 13, 14  Next
OuBallie
PostPosted: Sat Sep 22, 2018 4:24 pm    Post subject: I'm done with Google & and particularly Flickr! Reply with quote
Flickr:
Tried to log into the account I set up using their iOS App and tried every I could think of but no luck.
You would thing that would be simple, but anything Yahoo obviously isn't and I really REALLY cannot be bothered any longer!
Google Photos:
No way of embedding photos, just links.
I really cannot be arsed to download all of the relevant Google photos right now, BUT may do so once I've calmed down and steam out the ear holes ceases.
Someone please tell me what I am missing here.
Geoff - Pissed of I most certainly am!
Too many hobbies, not enough time!
1935 Austin Seven Ruby ARQ
1957 Austin A35 2-door
1967 Morris Minor 2-door
2007 Fiat DoblÚ MultiJet (It carries the spares etc)
Model Engineering
Penguin45
PostPosted: Sat Sep 22, 2018 6:22 pm    Post subject: Reply with quote
I have to log into my Flickr account by logging into Yahoo. Pointless really, as I don't use Yahoo otherwise.
P45.
OuBallie
PostPosted: Wed Sep 26, 2018 12:30 pm    Post subject: Reply with quote
P45.
I walked away from Yahoo when they killed the Groups.
Haven't used Yahoo since except for Flickr on iOS.
Geoff - Some with Flickr now as wełl.
Model Engineering
OuBallie
PostPosted: Tue Oct 23, 2018 3:17 pm    Post subject: Reply with quote
P45.
Model Engineering
OuBallie
PostPosted: Tue Oct 23, 2018 3:18 pm    Post subject: I'm done with Google & and particularly Flickr! Reply with quote
Flickr:
Google Photos:
Model Engineering
PostPosted: Wed Oct 24, 2018 9:22 am    Post subject: Re: I'm done with Google & and particularly Flickr! Reply with quote
What's wrong with postimage? It also accepted all the photos I had on photobucket with a single command.
1939 SS Jaguar 2Ĺ litre saloon
OuBallie
PostPosted: Fri Nov 23, 2018 11:49 am    Post subject: Reply with quote
Peter,
Oops haven't been on the Forum for a few months due to health.
Tried Postimage but for some reason we just couldn't get along, as happens when friends introduce you to someone.
However, the new owners of Photobucket have come to their senses following the utter greed fiasco and resultant bad press the original owners generated.
I will now be uploading pictures and will update my Thread as soon as.
Geoff - I hope/doubt 'new' P'bucket will make the same mistake.
Model Engineering
OuBallie
PostPosted: Fri Nov 23, 2018 5:41 pm    Post subject: Update at last as Photobucket no longer Ransomware! Reply with quote
Thank you to the the new owners of Photobucket.
You at least realised the damage the old guard did to thousands of Forums when they became members of the Ransomware Brigade.
Time for an update, starting with the Front Mud Wings/Shields, both OS and NS, as repairs where virtually identical.
Uploads are taking ages as usual so thought I would add whatever had uploaded, as the others are just showing patched holes and under coated when finished, and will add these later.
Geoff - I would think most/all Forums are breathing a sigh of relief.
Model Engineering
OuBallie
PostPosted: Fri Nov 23, 2018 7:12 pm    Post subject: This is it for Mud Shields Reply with quote
The holes mentioned patched using TIG with a few swipes with a body file and a little hammer and dolly work resulted in no filler needed.
Geoff - Next will be the NS Inner Arch repair
Model Engineering
PostPosted: Fri Nov 23, 2018 7:14 pm    Post subject: Reply with quote
Hello Geoff. Good to see you up, about and posting again. I guess that the monthly rates at PB will begin to climb in the future. I would wager that one day You-Tube will be by subscription.
With reference to magnets. I have a range of "welding magnets" some used as tool holders and one that is on the top of the pedestal drill. It looks after the chuck key and drill gauge for me.
https://www.toolport.co.uk/4-piece-mini-welding-magnets-30408-p.asp
OuBallie
PostPosted: Sun Nov 25, 2018 2:59 pm    Post subject: Another update Reply with quote
Thanks Peter.
Ordered a set of those magnets.
REPO
RubyEnginePartsOrganiser
https://youtu.be/apSP8QhDpgM
Geoff - They are coming fast now as a lot to cover
Model Engineering
OuBallie
PostPosted: Sun Nov 25, 2018 3:01 pm    Post subject: Ditto Reply with quote
Ruby engine, machining/mods
Manifold port face being machined.
https://youtu.be/zLBFv60GRNQ
Manifold Inlet machined flat
https://youtu.be/Q4Y1K_mlsTQ
Geoff - Ome more to come
Model Engineering
OuBallie
PostPosted: Sun Nov 25, 2018 3:09 pm    Post subject: Ditto Reply with quote
CylinderBlockWhatsit
https://youtu.be/7r9bcJjc0b4
Update
https://youtu.be/YJ5XWKEFoPY
Mounted on the Workbench bolted to those two lengths of square tube.
That magnet holding the LED in place was replaced with one used for Dial Indicators and so much more powerful.
Enough light I hope for grinding.
Geoff - Time for a breather I think
Model Engineering
OuBallie
PostPosted: Sun Nov 25, 2018 3:12 pm    Post subject: Last ditto for today Reply with quote
Cylinder block slicing
I got hold of two scrap cylinder blocks, early and late castings, so that I could slice them up not only see where they differed, but more importantly with the later block, to see where all the metal was and wasn't to help me decide where to grind when doing the ports.
Slicing CylinderBlock
Geoff - Last one for now.
Model Engineering
OuBallie
PostPosted: Sun Nov 25, 2018 3:30 pm    Post subject: Last ditto promise! Reply with quote
NS Inner Rear Wheel Arch
Photos of the complete process replacing all the bad metal and patches to accompany the video posted previously but added here.
https://youtu.be/SmSvyRa-up4
Cut this section out to make it easy to use.
Next bodywork will be to finally do the actual B-post repair.
Geoff - That's really it for today.
Model Engineering
Page 11 of 14
