Rain water - as coolant?
PostPosted: Fri Nov 22, 2019 5:40 pm    Post subject: Rain water - as coolant? Reply with quote
Given how much water is (literally) floating around at the moment, is rain water (and indeed that from a de-humidifier) suitable for use in a coolant mix in a car's radiator? I had a quick look around online but didn't find a definitive answer.
PostPosted: Fri Nov 22, 2019 5:49 pm    Post subject: Reply with quote
If you live in an area where your kettle "furs"up then I would suggest it is a lot better than tap water.
PostPosted: Fri Nov 22, 2019 7:39 pm    Post subject: Reply with quote
Yes we have hard water here, so I was thinking that it might be ok.
PostPosted: Fri Nov 22, 2019 8:17 pm    Post subject: Reply with quote
The only suggestion I would make about rain butt collected water is filter it, perhaps through a few layers of 'er indoors's discarded stockings/tights.
PostPosted: Fri Nov 22, 2019 8:27 pm    Post subject: Reply with quote
Good point, I wouldn't want to use my own after all
PostPosted: Sat Nov 23, 2019 6:18 am    Post subject: Reply with quote
Whenever possible I always used rain water in radiators. For the years 1990 to 2017 it became very easy as our only water supply was rain water collected off the house roof into tanks. Virtually no minerals in it. When living in an area of hard water via the mains, I would avoid putting it in the radiator unless no other option was available.
PostPosted: Sat Nov 23, 2019 7:55 am    Post subject: Reply with quote
The water from the dehumidifier goes into SWMBO's ironing machine. Our water here is very hard and we are for ever running white vinegar through coffee machines, the washer, the kettle and all. And it's about the cheapest household cleaner going!
PostPosted: Sat Nov 23, 2019 10:12 am    Post subject: Reply with quote
Hi lowdrag
Have you ever tried citric acid crystals?
I get them from a home brew shop only used a couple of teaspoons at a time.
I found them V effective and no taint to rinse out afterwards,
PostPosted: Sun Nov 24, 2019 12:00 am    Post subject: Reply with quote
I have a 1000l plastic tank gathering the rainwater from my workshop roof. I always use it in the Jowett Radiator. It dramatically reduces lime buildup in the cylinders
Churchill Johnson
PostPosted: Tue Nov 26, 2019 10:00 pm    Post subject: Reply with quote
Has anyone thought that if all these items get furred up what the hell do's it do to us............. Laughing
