Posted: Fri Oct 30, 2020 10:17 pm Post subject: |
The advert shows what looks like an electric heat gun being used. I have one of those and with a bit of fettling I could adapt a nozzle to direct the heat more accurately.
I imagine the plastic would melt with a naked flame? |
Miken
Posted: Fri Oct 30, 2020 11:38 pm Post subject: |
3000 degrees. That's Impressive. You have some serious ligters down your way. That's more than enough to melt steel. Almost enough to melt titanium. So should be enough for soldering i would think  |
Posted: Tue Nov 03, 2020 10:53 pm Post subject: |
| MVPeters wrote: | A butane cigarette lighter should be enough.
(I just ordered some connectors - I'll let you know!). |
My order arrived! I tested one with a cig lighter & it seems to work fine.
However, there are several videos on YouTube & it's worth watching 2 or 3 to see varying, though all positive, opinions. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Fri Nov 06, 2020 6:26 pm Post subject: |
I have also bought some. Although it gave the impression that it was British (Union Jack displayed) they are in fact made in China.
I obviously intend to use them for the car wiring but today I wanted to join a wire to an outside light (LED). Is there any reason why I should not use one of these for 230 volts? |
Joined: 14 Oct 2016 Posts: 2149 Location: East Yorkshire
Posted: Fri Nov 06, 2020 8:05 pm Post subject: |
| Quote: | Is there any reason why I should not use one of these for 230 volts?
Try it? Just turn the switch on.....carefully? _________________ Dellow Mk2, 1951 built, reg 1952.
alanb
Posted: Fri Nov 06, 2020 8:12 pm Post subject: |
Ray, it should be fine, mains lighting is normally only 2amp, for a given amperage the lower the voltage the thicker the wire _________________ old tourer
Morris 8 two seater |
Posted: Fri Nov 06, 2020 11:13 pm Post subject: |
| alastairq wrote: | | Quote: | Is there any reason why I should not use one of these for 230 volts?
Try it? Just turn the switch on.....carefully? |
ZZZZZZZZZZZZZZ
DOHHH!  |
Posted: Sat Nov 07, 2020 8:33 am Post subject: |
| Ray White wrote: | I have also bought some. Although it gave the impression that it was British (Union Jack displayed) they are in fact made in China.
I obviously intend to use them for the car wiring but today I wanted to join a wire to an outside light (LED). Is there any reason why I should not use one of these for 230 volts? | Being Chinese, I doubt they have any ratings, as Alan mentions they won't have to carry high currents (with a led lamp), so the concern would be is the insulation good for a higher voltage? Certainly the ones from RS are rated up to 1KV, I expect these will be similar.
They won't have an official IP rating, but are probably good to meet IP64.
All that said, for 240v jobs I would stick to Wago's or the like, especially if connecting solid wire to stranded (common when fitting lamps) . They are cheap, very quick and easy to use, more reliable than screw block terminals and importantly designed for the job.
If you have not used them before this video gives a good overview:
https://youtu.be/zWc_awaQFPg
The Wago 224's are specifically designed for lighting where solid cable meets stranded. https://youtu.be/y98v7NvuCVw
